Amlogic Android tool
Hello guys, im trying to fix my gamepad on AZW W95 android box!
How do i edit keymaps on amlogic android tool? everytime i press R1 it opens music player...if i press B it opens google chrome and it makes impossible to map and fix it!
I need to find a fix, does anyone knows where is this "shortcut" located to remove it?
I have also made an KL file to map it but the problem is still the same:
Thats my KL file content:
TX Shocker Gamepad - Microntek USB Joystick
key 288 BUTTON_Y
key 289 BUTTON_B
key 290 BUTTON_A
key 291 BUTTON_X
key 292 BUTTON_L2
key 293 BUTTON_R2
key 294 BUTTON_L1
key 295 BUTTON_R1
key 296 BUTTON_SELECT
key 297 BUTTON_START
# Joystick and game controller axes.
# Axes that are not mapped will be assigned generic axis numbers by the input subsystem.
axis 0x00 X
axis 0x01 Y
axis 0x02 Z
axis 0x03 RX
axis 0x04 RY
axis 0x05 RZ
axis 0x06 THROTTLE
axis 0x07 RUDDER
axis 0x08 WHEEL
axis 0x09 GAS
axis 0x0a BRAKE
axis 0x10 HAT_X
axis 0x11 HAT_Y
So any tips on how to fix it?
Originally posted by smrtprjcts View PostHi!
I made an android app to handle some amlogic device problems.
The function at that moment:
GP functions
- GP test: solution for unfortunately, Google Play Store has stopped problem. Get new GP. Root needed
- Revert: back to original GP. Root needed
- Periodical check: background process for checking new GP
Display related functions
- CEC keep-alive: some devices lose cec functionality after switch to another source (eg. tv or other hdmi). this can solve the problem
- Auto frame fix: some devices has wrong rights for auto framerate in SPMC or FTMC. root needed
- Auto frame rate: it can be enable/disable the auto frame rate of the system (it can be work with other app (eg: mxplayer, not only from spmc/ftmc)
- Noise Reduction: it can be enable/disable the noise reduction
- HDMI RGB color mode
- Display settings: contrast and brightness settings
- Display resolution: switch among supported resolutions
- HDMI info: shows some interesting hdmi info and plugged-in tests
Hardware related fuctions:
- MMC Info: shows some useful info about the mmc (manufacturer, date, serial, etc)
- Wifi Info: shows some useful info about the wifi chip
Init.d support: it creates the init.d directory where you can put your scripts or you can edit a pre-created default script (myscript.sh) from the app (init.d script editor menu).
Init.d editor: edit the default app created script
Img unpacking: it can unpack the amlogic img files
Restart: it reboots the device with different types (from sd card (without push the reset button on the device), from recovery, etc)
If someone tries it please send the hdmi info report with the report button (at the bottom of the dialog).
Ps: any ideas, further fuctions, problem descriptions are very appreciated (from feedback menu)
It's on Play, you can try it
Thanks a lot
Temperature related things: here
Ps: it's tried on S905 and S912 but should work on S8xx
GP functions
Thanks a lot
no activity to send email. from the report button
zoomtak upro 3/32 misconfigured as a uplus
Have to say this is a great app. Been trying to find a way to update playstore on my tanix tx92 and this did the job
Have paid for the pro version of the app as it has come in very useful. Would be a nice perk to make the pro version an ad free experience though without the ad banner at the bottom of the screen.
Any other features that are in the works at the mo for the app?
Sent from my ZTE A2017 using Tapatalk
GP functions
Thanks a lot
There are currently 2698 users online. 1 members and 2697 guests.
