R-TV BOX S10 DDR4 3/32GB Android 7.1 4K TV Box S912 AC WIFI Gig LAN BT 4.1
    Thanks Clarkss+
    hvnt tried yet of LibreElec;but I'll try it and need some experience for this app.
    I guess or seems that AMLogic has some problematic video pic. quality
    Beside "Audio" is not my intereset so all of are OK lol
    "SD" video AmLogic really bad! therefore tried "internal player" but its sucks! tried SPMC sucks also
    my Panels and BDs far superior if I compare with AMLogic
    But "HD" video OK even all devices are OK(I ignore "details" as well) if not ignore BDs still far away superior too!
    So those boxes for "other purposes" then if you look from this window those boxes amazing
    Bye++
      The 3/16gb version of the S10
      Coupon Code $2 coupon: RTVBOX316
      Geekbuying
        I'll buy 3/32 tomorrow+
        $ 66,89
          Originally posted by trebor View Post
          Well you asked for it so here it is
          3/32GB: RTVBOXS10 $15
          Only cause you asked
          Geekbuying
          thanks
            $ 66,89
            use coupon code RTVBOXS10 USD 64.99
              Yes just checked myself,
              Not much can be done until they awake in about 6~8 hours..
              Will suss it out later.
              Later:
              Yes can confirm that coupon has expired.
              $2 is the current offer.
                Later:
                RTVBXS10 coupon code works fine
                R-TV BOX S10 KODI 17.3 DDR4 3GB eMMC 32GB Android 7.1 4K TV Box S912 AC WIFI Gigabit LAN Bluetooth 4.1 USD 64.99
                R-TV BOX S10 KODI 17.3 DDR4 3GB eMMC 16GB Android 7.1 4K TV Box S912 AC WIFI Gigabit LAN Bluetooth 4.1 USD 58.99
                R-TV BOX S10 KODI 17.3 DDR4 2GB eMMC 16GB Android 7.1 4K TV Box S912 AC WIFI Gigabit LAN Bluetooth 4.1 USD 49.99
                  Today we get to have a close look at the S10 - R-box 2/16gb same spec just a little less ram
                  Thanks to Geekbuying and Dhl super fast as always:
                  The Box
                  What's in the box
                  Removed protection
                  Front
                  Ports
                  R-TV BOX S10, Android OS: Android 7.1OS Amlogic S912 Octa core ARM Cortex-A53 CPU ARM Mali-T820MP3 GPU up to 750MHz (DVFS)
                  2GB DDR4, 16GB eMMC, WiFi, 802.11a/b/g/n/ac, 2.4G/5G, 100M/1000M, Bluetooth: BT4.1
                  Look on the inside:
                  Not much Ventilation, Small heat sink, Barrel WiFi antenna under this Mass of Alloy Lid, this all could be fun:
                    Cant wait till mine comes the 820 and ddr4 plus the specs made it a sweet deal. Firmware always the bit of sore point because they are always consistent and they on stock it sucks but i am always waiting to be surprised. Lol but nice shinny box
                      Lets have a look at the UI and then some deep and meaningful testing a little later
                      Ok Looking Ui
                      Different you don't add Favorites to lower bar it does a History of them and places them down below
                      Also has a setup wizard, did not run at start can be done manually usual, Language, region full screen etc also some information about UI and remote.
                      Installed Apps
                      Netflix that is Installed is an old version and has been adjusted so it will not update.
                      S10 also has Root
                      Running Android 7.1.1, Build q201 20170622 test keys
                      Also have the friendly Rocket Launcher to clear memory
                      Using Logitech Keyboard mouse can have some problems not properly detected, if you turn off the virtual OSK you may have some problems.
                      Remote as good as it looks and feels will also get a bit lost, put that down to early A7 release needing some work.
                      Update August 2 OTA update has fixed the following Playstore Problem
                      Tho it should not happen,
                      It has with this box many apps for testing and games Not compatible, so more work needed in that area me thinks, Just a few of the Many
                      Many of the Bench tests Apps also not compatible
                      But what we have we can show...Overall performance is OK, no great speeds,
                      Ram Speed is so so have seen a lot better as you will see
                      The rest much the same as other S912 running DDR4
                      The Remote is OK, a better look and feel than the standard type that have been around, line of site ok at a distance.
                      But could do with some improvements
                      No excessive heat problems, but as 3Dmark, Antutu not compatible at present not pushed
                      No Upper/Lower task bar at present or option to enable.
                      Those with the 3GB units may a better ram speed....
                        I left the Hunk of Alloy of the top as I wanted to monitor temps and they are ok...
                        But also I wanted to see if it would do anything to WIFI signal.
                        Hmm well it does appear to impact as you will see
                        Same location about 2 meters from the Router, Lid off, then on and same again
                        Looks like this one is going to need an outside antenna
                          Not shown as an App there is version of Kodi Installed - KDMC
                          Youtube playing in 1080 on a 1080 TV
                            New Firmware:
                            http://freaktab.com/forum/tv-player-...337#post658337
                            Some troubles with my S10
                            Cant get it to detect to flash
                            They advise Goggle Play problem have been resolved with incompatible apps.
                              Dear Friend,
                              Can you run netflix and youtube in 1080p and 4k? Is it compatible with 5.1 and 7.1 audio dts and dolby?
                                1080p YT, Netflix No, not able to test 5.1 presently but I think it should.
                                Still waiting for OTA update to fix current Playstore problems
