I intend to buy this box. Is it worth it or would it have another better box in the same price range?
R-TV BOX S10 DDR4 3/32GB Android 7.1 4K TV Box S912 AC WIFI Gig LAN BT 4.1
Originally posted by trebor View Post
Originally posted by trebor View PostNot sure
i just installed this about 30 minutes ago and ran it..
As I could not previous....
This is the 2/16 unit ...
These Boxes alway start a little ruff but get sorted sooner or later and with any luck a custom rom may appear and all will be better that it is but all takes time
I thought Zidoo X6Pro was slow. This one is slower. Mecool BB2 Pro is a much faster box when I tried two of them. I thought this was even better having newer OS and more ram in DDR4.
Try playing a 1080 movie for an hour or so. Mine kept crashing.
Yep one Hot box this unit......Idle we are running about 55c, Testing with 3dmark we peaked at 80c
Temp in upper centre of screen,
Tin lid good for keeping the Heat In.
Originally posted by trebor View PostIf you're using Kodi and all that JUNK addons., maybe not helping
try a reflash start fresh see what happens, avoid the installed kodi try FTMC
Installed FTMC fork via Android Buddy 2. Horrible. Dog.
Box definitely gets hot. Had overheating and turned it off. Lay it on it's side.
Not much clearance at the bottom. This box needs to be on it's side with a USB fan.
Never had this kind of problems on Mi Box or Mecool BB2 Pro. Had some problems with Zidoo X6 Pro but nothing close to this box's.
Originally posted by jrbrown View Postworst box ever will not boot up after 1 day
So far it has not croaked.
How is the heat after all the hours of playing?
I'm still getting a USB notebook fan though. It's a cheap precaution.
If there's a software that I can install to check it's working conditions, let me know.
I'm all for helping all hobbyists here.
I still consider this a hobby. Used to be on satellite tv programming and emulation hobby too till it died.
Scooter, I don't know what a build number is. Serial number on the box is 238209 if that helps.
There are currently 1842 users online. 2 members and 1840 guests.
