R-TV BOX S10 DDR4 3/32GB Android 7.1 4K TV Box S912 AC WIFI Gig LAN BT 4.1
    blinkone, I just tried all of image files in that link you gave me. 9% UBOOT/Partition_aml_dtb/verify partition/Error result. The moment it gave me errors, I pressed reset button, nothing happens. Repeat many times, nothing. Unbelievably frustrating. Thank you for all the help though, appreciate it.
      anyone knows about mac-ether.ini file? How to check that I have the correct setup for it?
        Have you tried other versions of the burning tool? Might be worth a go
        Try other ports on your pc
        Another idea is to add the power adaptor just before it fails the flashing process
        And another idea is to try the burn card maker and try and flash it using the SD card
        Burn card maker and instructions
          Appreciate all the suggestions and help, thank you.
          I have tried burn card maker, nothing happens at all.
          Other versions of burning tool don't have licence folder at all, and don't have mac-ether.ini file. I am asking for help with mac-ether.ini file, but no one seems to have an idea about it.
          Without the power adapter attached to the box, burning tool never sees the box.
            Don't give up keep at it, may be take a tea break to clear your head lol
            I never use the power adaptor to flash any of my box's but I have seen that others need to use it though.
            With the other versions of the burning tool that don't have the licence folder,Just copy and paste the licence folder with all its contents from the burning tool that does have it to the ones that don't have it.
              great idea, blinkone, I need a break, I am so tired, mentally mostly. Also, I will try the older versions of usb burning, with your suggestions. Thank you again so much. Appreciate it.
                Hello.
                Sorry for being back at the same problem. The flashing stops at 10% "Download Boot". Does anyone know what "Download Boot" inside Usb-burning-tool mean? The Usb-burning-tool starts fine:
                1% Download DDR -- fine
                4% Download UBOOT --- fine
                8% Download boot ---- fine
                10% Download boot ----- stays there for about 5 minutes and then error: "UBOOT/Partition boot/Verity partition/Timeout error"
                Every little help would be greatly appreciated as always.
                Thank you.
                  I'm not sure, but I had a similar stoppage.
                  When I plugged in the power cord immediately after the USB cable, the installation has passed
                    However, too many issues with R-tv S10: Su updates leading to boot loop, new firmware not booting, difficulty in flashing firmware: not working from SD card, no support....
                    I bought a Beelink GS1 now, and till now not even a problem.
                      Thanks everybody for all your help, appreciate it.
                      darko150, to make usb-burning-tool to detect the box, I have to plug in the power supply. I have read here that some people flash their unit without even attaching a power supply to it.
                      From what I got from your post: first you plug usb cable, then power supply, then short the pins inside the box to put it in recovery mode, then start flashing? Is that your procedure?
                      Could you please explain? Maybe the order of doing the whole procedure matters, so, could you please describe the order of things for you? appreciate it
                        Are you using these settings? Click image for larger version
                          Yes, exactly those.
                            Well, I flashed this my box many times...
                            its behavior is unpredictable: some time I have to squeeze the reset button, some time it is enough to just turn on the Usb 2x male cable without reset button, sometimes it should also include a power cable...
                            Sometimes stops at 7, sometimes at 10, sometimes at 96%, then combine reset, usb, power and in some combination pass flash
                              Thank you for your reply, darko150, I appreciate it.
                              Mine never passes 10%, no matter what I do. But I will keep at it.
                              Thank you.
                                Did you try with: Force erase all. For me sometimes is worked
