R-TV BOX S10 DDR4 3/32GB Android 7.1 4K TV Box S912 AC WIFI Gig LAN BT 4.1
Since H-Tab is asking about TWRP, I was thinking: can I do something different maybe using TWRP? You all know my problem: I can't flash my R-TV S10 3G/32G DDR4 android tv box.
With sd card method: Instead of putting the S10 image on the card, can I put TWRP? And then it will flash TWRP on S10, and take it from there? Does this make sense?
With usb-burning-tool method: can I flash TWRP image? Does it make sense? Or, TWRP is not an image at all? I admit, I know nothing about TWRP.
What do you guys think about this? Any ideas?
Thank you, darko150, appreciate it.
I put both recovery.img and text.zip files in sd drive. With the sd card inside box, I short the pins on S10 box, I see the tv screen changes from "no signal", to 1080p picture, but it is a black picture, nothing on it.
I changed many tv's, or hd cables, the same result, black screen.
Any suggestions?
Anyone?
Thank you.
darko150 - when I press reset button, nothing happens.
I put S10 box in recovery mode only using shorting the pin method. Just like post #22 in this thread:
http://freaktab.com/forum/tv-player-...-version/page2Last edited by mn.ll.eo; 11 March 2018, 08:23.
i have the S10 box and when i press the reset button and power, it just says erasing and then boots up i never get to the android guy recovery screen. i have also tried to root using twrp recovery.img on sd card and the same thing happens when i press reset and power. can someone please give me some help with this?
There are currently 6604 users online. 2 members and 6602 guests.
