R-TV BOX S10 DDR4 3/32GB Android 7.1 4K TV Box S912 AC WIFI Gig LAN BT 4.1
ok, then, good news, the memory may not be faulty, since I know that the box goes to recovery mode and boots fine when I short the pins.
I did sent a message to the company in China, and, to my surprise, they replied back, and told me they will get back to me after analyzing the problem I described to them. So, hopefully they do have a "magical-private" software to flash the memory.
thank you, cisit, and everyone who is willing to help, appreciate it.
I had to try several times and try several USB ports of the box, power cable was always in (I don't know how others could flash without it, maybe with computer USB power), then suddenly I got the box detected and flash was fine (22092017). I used a USB 2 memory stick for the flash,32GB . What are you using?
Here is what I do, 2 ways:
1) box connected to power supply; connect the box to computer with usb type A male to male cable; short the pins on s10 box, run flash on usb-burning-tool, it goes up to 10% Download boot, and then error. No signal on tv at all times.
2) prepare sd card using Burn_Card_Maker. Put sd card on s10 box. Connect the box to power supply. Short the pins on s10 box, while pressing reset pin, the tv screen turns completely green, picture is 1080p, and nothing happens after that, even for hours.
What do you use USB 2 memory stick for?
There are currently 2062 users online. 1 members and 2061 guests.
