That sleep mode is annoying .
R-TV BOX S10 DDR4 3/32GB Android 7.1 4K TV Box S912 AC WIFI Gig LAN BT 4.1
Originally posted by ardentbuzz View PostHad this box kodi installed OK but box crashed while watching a movie
There was a kodi icon on home page when I got the box and ot was already running Kodi 17.4 I was very impressed but it only lasted 3 days..
After it crashed (3 days) I did a quick recovery (tooth pick method) and reinstalled kodi but although it was showing Kodi in the System/apps as being installed it would not run..
I contacted the people I bought the box off and they directed me to a link where I could download the software for the box which I did but could not get the box to connect to my PC via USB burning Wizard so now I got a brick box which now will not even go to quick recovery (tooth pick method)
Not happy asked for a refund!!!
This box has problems. Mine wouldn't send a signal through the HDMI cable to the TV when you turn the power on with the remote. I would get no HDMI connection on my tv. The only way to get it to work was to unplug the power cord and plug it back in. I was told to go buy another HDMI cable and charger and see if that works. So I do that and now it won't event turn on now matter what I do. I guess I'll chalk this up as a loss because It's not worth spending $30 or so to ship it back to China.
im having issue with the box going in sleep mode and have to restart after taking the cord off everytime. my box updated to 7.1.2 and now the android settings are changed i can not find the power option anywhere,this new upgrade is worst. please help.
Originally posted by panchovilla View Post
Switch the power mode to off in the settings ( Power ) .
I have given up with this box. It seems to be completely screwed up. I am unable to flash it using Armlogic USB flash tool 2.008 I get error 0x30201004 at 7% burn.. I tried using Armlogic SD card maker and it will boot of the SD card to the android screen but goes into a continuous loop Upgrading.. very frustrating cos the SD card method seems to have promise. It stops upgrading only about 15 seconds after it boots which would be about 7% of space done along the upgrade line so I thought it maybe the latest firmware so I found a copy of original firmware (7.1) but when I try to boot with that (SD card) I get blank screen.. Tried Googling the error but no luck .
Can someone HELP???
SUCCESS at last!!!!
Burn the image to SD card (no bigger than an 8gb card) using Armlogic SD card maker
Put card in sd card slot and then connect power and it should boot to screen in photo above... when you see it trying to do an upgrade remove sd card then pull plug
Put card back in and reconnect power and it should finish the upgrade
Hope this helps as I been 2 weeks sorting this out
Tried to do upgrade again as above but box will not connect to tv at all
This is a very nice looking high spec box but it has issues and I can not recommend it until maybe a new image is available
Iv been playing around with the 2/16Gb version of the R TV BOX S10 for a few weeks now,Some days it will work great then other days it sucks.Im Using stock FW 20170722 it says I'm on the latest FW
Will try supercelerons new alfwise ddr3/ddr4 firmware Once the review is donePlease consider making a Donation to freakTab
Originally posted by blinkone View PostIv been playing around with the 2/16Gb version of the R TV BOX S10 for a few weeks now,Some days it will work great then other days it sucks.Im Using stock FW 20170722 it says I'm on the latest FW
I have a S10 box and want to have my apps on the home page. Does anyone know how to add apps to a new launcher? All my apps don't have shortcuts. I read that if I press longer on the app then I can drag it to the home screen. My experience is that no matter what type of press (long or short) results in the app starting.Last edited by avs1232003; 25 September 2017, 21:40. Reason: Let me revise the question: how do I add app shortcuts on the standard launcher?
There are currently 2367 users online. 1 members and 2366 guests.
