[ROM] Mecool M8S PRO+ Stock & Nano Nexus ROMs (Android 7.1)
Originally posted by Karce View Post
Honestly I'm a minimalist, so I would use the NANO and install what you need. The Stock variant has all the extra google apps which I do not need (such as play video, play music, etc) and therefore do not want it possibly running in the background. On boot, I have over 60% free RAM (1.2GB free).
Plus it prevents any possible extra services causing issues.
1 comment- #29.1
Magendanz commented
09-25-2017, 10:58
Keep in mind that you've got a 2GB system partition, regardless of whether it's filled or not. While the Nano variant is considerably smaller, you don't get to recover that unused space for user storage. And for the most part, these variants run the same underlying services and the additional apps don't take up RAM unless they've being run.
I have the same problems as many others had. After installing the OTA package, my device got stuck and it won't do anything. I have ordered a male to male USB cable so I will be able to try the USB burn method. Just a question, should the sd option be also a good choice for me? And, where's the reset button in our device? Because if I use a toothpick I can't find any button, meaning I can even put it into the device. Thanks!
Originally posted by resadent View Post... And, where's the reset button in our device? ...
I installed the nano from update with zero problems, ensuring to select 'wipe data' I believe is an important factor.
Post Scrip Edit - not sure if makes any significant difference but I had the ROM zip in the external SD card
Update on root -
I installed supersu.zip from TWRP and now I get a prompt to allow when each app is selected
- very straight forward, search for supersu-zip, download it & select 'install' from TWRP and navigate to the file location
In short order, am VERY impressed with this ROM - no 'fluff' and allows you to select your own Apps - everything is running great with it
I don't use Netflix, but just installed Amazon Prime Video and it looks very good.
As an update from an earlier post I made, addition of external Antenna actually DID improve the WiFi performance, although I'm now using a Powerline Adapter with it.Last edited by DEcosse; 26 September 2017, 01:19.
Originally posted by DEcosse View Post
http://freaktab.com/forum/tv-player-...688#post660688
Update on root -
I selected "wipe data" before installing the rom, but it changed nothing in the end. Hope I am luckier next time.
Originally posted by resadent View PostThank you. I will try tomorrow to reflash it with an sd, and if I have no luck I'll try USB Burning Tool.....
Maybe restore back to OEM and try again
Originally posted by resadent View PostI have the same problems as many others had. After installing the OTA package, my device got stuck and it won't do anything. I have ordered a male to male USB cable so I will be able to try the USB burn method. Just a question, should the sd option be also a good choice for me? And, where's the reset button in our device? Because if I use a toothpick I can't find any button, meaning I can even put it into the device. Thanks!
FYI - See this response from Guest - http://freaktab.com/forum/tv-player-...563#post662563
Originally posted by DEcosse View PostI know that there was "no update available" for my box (i.e. it was not offering update to take it to the 20170829) - therefor I wonder if there has been a hardware change and that is why the OEM ROM is different (and why the custom ROM is not working?)
I have already updated to the Nexus ROM so the OEM firmware version is moot
However my order shipped from Geekbuying on 8/22 which clearly pre-dates 8/29 - and I had no OTA update that it found. I certainly did not execute an update.
Originally posted by grimmie View Post
For that to work you will need the original OEM ROM. If like me, it's something that I dont have because the original oem rom version 20170829 is not available..
You might still go ahead and try to flash in the OEM 8/15 ROM (as per the link) - if there is no hardware change, then it should install and you can see where you are from there.
If that won't take, then indeed something may have changed
Hi!!
Thanks for this awesome ROM! I have one issue though:
Originally posted by Magendanz View Post- Recovery from sleep/standby seems to result in a full boot. This seems to be a bug in the underlying OEM firmware.
SD card is brand new, 16gb Sandisk Ultra Class 10... So I don't think it is card issue. Rather issue is caused by box not going to sleep mode well, filesystem gets corrupt.
Anybody encountered same issue? Can I avoid it somehow? The full boot is rather painful... Any chance to fix this?
Originally posted by DEcosse View PostI have already updated to the Nexus ROM so the OEM firmware version is moot
If we assume for a moment that 8/29 is merely a later revision based on same hardware, there is no reason why you could not flash 08/15 version - it should not HAVE to be same you started with
i guess we will have to not assume because the manufacturers or sales companies aren't exactly ISO certified.
You might want to know that two weeks apart and the hardware is different. You can photo from other forum chain.
There are currently 3633 users online. 0 members and 3633 guests.
