[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Guest
Hi Folks,
i have a GT1 with serial A912, current ROM is the stock from Beelink 708N0_AP6255.
When i try to burn one of the images from here (tried with usb burning tool 2.0.8 and 2.1.2) i am getting an error right at the beginning of the process after "Download DDR".
Burning the stock from Beelink goes just fine.
What could be the possible reason for this?
Code:[11:41:11 272][HUB5-1][Inf]-------------Download DDR.USB----------- [11:41:11 272][HUB5-1][Inf]--2-2-0-0 [11:41:11 272][HUB5-1][Inf]--Control write pll reg1 0xd9000000:0x000000b1 [11:41:11 773][HUB5-1][Inf]--Control write pll reg1 0xd9000000:0x00005183 [11:41:12 274][HUB5-1][Inf]--Write initial succeed [11:41:12 274][HUB5-1][Inf]--Upload encrypt at 0xc8100228 [11:41:12 274][HUB5-1][Inf]--ulValue = 0xadfc318c [11:41:12 274][HUB5-1][Inf]--Read encrypt value succeed [11:41:12 281][HUB5-1][Inf]--Transfer complete [11:41:12 281][HUB5-1][Inf]--Run at address 0xd9000000 [11:41:12 282][HUB5-1][Inf]--RunInRam succeed [11:41:12 658][HUB5-1][Inf]--IOCTL_IDENTIFY_HOST_Handler ret=-5 error_msg=libusb0-dll:err [control_msg] sending control message failed, win error: A device attached to the system is not functioning. [11:41:12 658][HUB5-1][Err]--CheckFileRunState failed [11:41:12 658][HUB5-1][Inf]--Failure : 1, FailureMax : 3 [11:41:12 660][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE [11:41:12 661][Global][Inf]--Scan usb device [11:41:12 661][Global][Inf]--Aml scan WorldCup Device [11:41:12 663][Global][Inf]--Host: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D [11:41:12 663][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e2d&subsys_16e810cf&rev_04#3&11583659&0&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [11:41:12 664][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&2278ac73&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [11:41:12 664][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&a287287&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [11:41:12 664][Global][Inf]---------->[Port0]NoDeviceConnected [11:41:12 664][Global][Inf]---------->[Port1]NoDeviceConnected [11:41:12 665][Global][Inf]---------->[Port2]Other device [11:41:12 665][Global][Inf]---------->[Port3]NoDeviceConnected [11:41:12 665][Global][Inf]---------->[Port4]NoDeviceConnected [11:41:12 665][Global][Inf]---------->[Port5]NoDeviceConnected [11:41:12 665][Global][Inf]-------->[Port1]NoDeviceConnected [11:41:12 665][Global][Inf]-------->[Port2]NoDeviceConnected [11:41:12 667][Global][Inf]--Host: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26 [11:41:12 667][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e26&subsys_16e810cf&rev_04#3&11583659&0&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [11:41:12 667][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&1e2e9ada&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [11:41:12 771][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&339a2dae&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [11:41:12 771][Global][Inf]---------->[Port0]NoDeviceConnected [11:41:12 771][Global][Inf]---------->[Port1]NoDeviceConnected [11:41:12 771][Global][Inf]---------->[Port2]NoDeviceConnected [11:41:12 772][Global][Inf]---------->[Port3]Other device [11:41:12 772][Global][Inf]---------->[Port4]NoDeviceConnected [11:41:12 773][Global][Inf]---------->[Port5]Other device [11:41:12 773][Global][Inf]---------->[Port6]NoDeviceConnected [11:41:12 773][Global][Inf]---------->[Port7]NoDeviceConnected [11:41:12 773][Global][Inf]-------->[Port1]NoDeviceConnected [11:41:12 773][Global][Inf]-------->[Port2]NoDeviceConnected [11:41:12 775][Global][Inf]--Host: USB xHCI Compliant Host Controller [11:41:12 775][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1e31&subsys_16ee10cf&rev_04#3&11583659&0&a0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27} [11:41:12 775][Global][Inf]---->Roothub:USB#ROOT_HUB30#4&332fa869&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8} [11:41:12 775][Global][Inf]-------->[Port0]NoDeviceConnected [11:41:12 775][Global][Inf]-------->[Port1]Other device [11:41:12 775][Global][Inf]-------->[Port2]NoDeviceConnected [11:41:12 776][Global][Inf]-------->[Port3]NoDeviceConnected [11:41:12 776][Global][Inf]-------->[Port4]NoDeviceConnected [11:41:12 776][Global][Inf]-------->[Port5]NoDeviceConnected [11:41:12 776][Global][Inf]-------->[Port6]NoDeviceConnected [11:41:12 776][Global][Inf]-------->[Port7]NoDeviceConnected [11:41:12 776][Global][Inf]--Scan USB host controller complete [11:41:12 776][Global][Inf]--Update data center with HubMap [11:41:12 776][Global][Inf]--Update hub5 device data [11:41:12 776][Global][Inf]--Update HUB5-1 [11:41:12 776][HUB5-1][Inf]--Update device path [11:41:12 776][Global][Inf]--Update HUB5-2 [11:41:12 776][HUB5-2][Inf]--Update device path [11:41:12 776][Global][Inf]--Update HUB5-3 [11:41:12 776][HUB5-3][Inf]--Update device path [11:41:12 776][Global][Inf]--Update HUB5-4 [11:41:12 776][HUB5-4][Inf]--Update device path [11:41:12 776][Global][Inf]--Update HUB5-5 [11:41:12 776][HUB5-5][Inf]--Update device path [11:41:12 776][Global][Inf]--Update HUB5-6 [11:41:12 776][HUB5-6][Inf]--Update device path [11:41:12 776][Global][Inf]--Update HUB5-7 [11:41:12 776][HUB5-7][Inf]--Update device path [11:41:12 776][Global][Inf]--Update HUB5-8 [11:41:12 776][HUB5-8][Inf]--Update device path [11:41:13 159][HUB5-1][Err]--[11:41:13 159][HUB5-1][Inf]--Failure : 2, FailureMax : 3 [11:41:13 660][HUB5-1][Err]--[11:41:13 660][HUB5-1][Inf]--Failure : 3, FailureMax : 3 [11:41:13 667][HUB5-1][Err]--[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error [11:41:13 667][HUB5-1][Inf]--Close device handle 0x0000072c
Hello, in France in my city, the deployment of fiber has arrived. So i noticed a bad debit in wired. How can i check this slowness ? My bit rate does not exceed 180 Mo/s. Do you have any commands to send me to test the ethernet card ? Is the network card flanged by hardware or android tv ? Thanks in advance.
Beelink GT1 s/n A912 + amlogic q201:7.1.2/NHG47L/20171221
Originally posted by Sonyroc View PostHello, in France in my city, the deployment of fiber has arrived. So i noticed a bad debit in wired. How can i check this slowness ? My bit rate does not exceed 180 Mo/s. Do you have any commands to send me to test the ethernet card ? Is the network card flanged by hardware or android tv ? Thanks in advance.
PS: When the burning tool wrote [HUB4-1] there was the same error. When I changed the connector, burning tool showed [HUB1-1] and it worked.
Originally posted by Magendanz View PostOkay., because my OneDrive cap got lowered to 30GB when my annual O365 subscription expired a few days ago, I'm going to do a pre-release through the FreakTab archive site for now. This will be updated with faster links when I'm bumped back up sometime in the next 48 hours.
Important Note: The underlying OEM firmware seems to be only compatible with the Beelink GT1 Ultimate LPN1 hardware. There's considerable risk to flashing this on older hardware revisions. (I had to do a Mask ROM Mode recovery on my Alfawise S92.)
Changelog (20190223):- Based on latest OEM firmware release for the GT1 Ultimate LPN1 (GT1_710N1)
- Live Wallpaper service (and factory live wallpapers) are restored to Nano and Stock builds
- Updated to TWRP Recovery 3.2.3-0 using minimal OMNI twrp-8.1 branch and latest OEM kernel
- Latest build from Open GApps (20190224)
- Nano Variant: BURN PACKAGE (1.22GB IMG file), OTA UPDATE (620MB ZIP file)
- Stock Variant: BURN PACKAGE (1.52GB IMG file), OTA UPDATE (814MB ZIP file)
- TVStock Variant: BURN PACKAGE (1.29GB IMG file), OTA UPDATE (678MB ZIP file)
Can you pls provide more details about this ROM, I have LPN1 ''10" gt1 ultimate device, i would like to try it.
Kindly let us know if someone else installed it, it will be great if the screenshot is provided.
There are currently 2242 users online. 1 members and 2241 guests.
