[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Originally posted by Samekas View PostAwesome ROM, beetween this and the http://freaktab.com/forum/tv-player-...ndard-ultimate which is better in terms of performance? Thank you!
The latest ZIP you linked didn't work for me (Bluetooth working but not WiFi), while the first one worked fine.
I have another question regarding B706 models, do you know why they cannot be powered down programmatically ? "reboot -p now" and "halt" commands both reboot it. Is that possible that they added this to prevent accidental shutdowns (because you know, there is no power button) ?
edit : TWRP's power off button works fine though
edit2 : I now have a A706 which I cannot power off and AP6335, I think they were wrong on the S/N of this oneLast edited by natinusala; 28 February 2018, 17:42.
Burn it on a COOLEME MB2 and it’s so great so far. Just tested couple hours.
My biggest problem with stock rom was an issue on Plex with pass through audio and it’s gone.
Everything is so much better. Speed, look and feel, navigation. Stock remote working with mouse mode, wifi ok, rj45 ok, didn’t try to connect a Bluetooth device cuz I don’t have but a MacBook is visible I guess it should work.
The hardware on that box is pretty good but I didn’t know it was so good before ur rom. I really have a new and powerful box with your work so I sent u 10 usd that’s the minimum compares to the changes to me.
Hardware is definitely not everything and can’t realize how bad the stock rom was.
Originally posted by Magendanz View PostI think I've got a workaround for the Bluetooth audio stutter on the Longsys LTM8830.
It seems the Shiningworth All-in-One firmware does a runtime check to determine the wireless chipset, then loads a Broadcom (libbt-vendor.so) or Qualcomm (libbt-vendor-qcom.so) Bluetooth vendor library depending on the results. Currently, it's getting the match wrong for the Longsys LTM8830, which is a Qualcomm QCA9377 clone.
To correct this on an affected device:
1. Reboot into TWRP Recovery and mount the System partition.
2. Open TWRP File Manager and delete /system/vendor/lib/libbt-vendor.so.
3. Rename libbt-vendor-qcom.so to libbt-vendor.so.
4. Reboot to System
You shouldn't need to wipe data or cache, and there are no new files needed. It should just load the Qualcomm vendor library from that point on and the audio stutter should be gone.
UPDATE: tillaz87 made a patch here that can be applied in Settings->About-System Update or TWRP recovery.
There are currently 5647 users online. 1 members and 5646 guests.
