good rom thank you. It work very well on my rtv box S10.
[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Originally posted by ridfa1 View Post
Hi magendanz,
I can test for you. Let me know if I can help.
thank you!
I am on the road. I will test the stock Rom next weekend. I have only 2GB of ram and the ram of the vorke z6 box is 3GB. Do you know if it can be an issue?
thanks for your support!
Thank you very much, I have updated via information settings by setting the flag also on wipe data. Result ok, the root with Magisk is gone and there is only your default one. Thank you so much for the excellent advice. The apps are left NOT deleted. GuestLast edited by Yugo79; 24 January 2018, 16:54.
Originally posted by Philbra View PostBonjour
telechargez le fichier OTA
Mettez le sur la carte SD ( interne ou externe)
puis après reboot en TWRP, mettez a jour en prenant le zip OTA
Cela marchera la version de novembre sans que vous perdiez quoique ce soit
philippe
hello, I downloaded the OTA version but I can not understand it is a ZIP and burn-card maker request an IMG file so I can not put it on a Sdcard how to do? or I dezip and I put on the card in copy / paste? thank you sorry for the inconvenience! thank's
Originally posted by Gag92 View Post
bonjours, j'ai telecharger la version OTA mais je n'arrive pas a comprendre c'est un ZIP et burn-card maker demande un fichier IMG donc je peu pas le mettre sur une Sdcard comment faire ? ou je dezip et je mets sur la carte en copier/coller ? merci désolé du dérangement et merci
reboot in recovery mode and upload the zip file.
img file is for USB full upgrade and will reset all your box
philippe
Originally posted by phateticwaltz View PostHi!
I've lost my gt1 IR remote, is there any remote app that can emulate the IR remote? my phone has an IR blaster, thus I want to use my phone as a remote (like I do for my tv).
thanks
How else do we modify the build.prop file?
thanks
I have the IR code generated, of if you tell me where to find it on the phone, I can share it.
Thanks for great ROM. Just upgraded my GT1 with OTA "20180119" version. Everything works great. The only glitch is when I left GT1 to sleep - after waking up I have to restart box because I can't play smoothly any video ... seems like LAN or CPU wakes up into 50% working mode. After restart everything works great again.
I've been having issues with the Bluetooth auto connect feature since the november update ; when I reboot the device, it doesn't try to connect to my BT remote. I can see this on the logs :
Code:01-24 14:58:59.061 4628-4628/com.android.bluetooth I/BluetoothAutoPairReceiver: Received ACTION_BOOT_COMPLETED 01-24 14:58:59.062 4628-4628/com.android.bluetooth I/BluetoothAutoPairReceiver: Need autoconnectBT! 01-24 14:59:34.111 4628-4628/com.android.bluetooth E/ActivityThread: Service com.android.bluetooth.hid.BluetoothAutoPairService has leaked ServiceConnection android.bluetooth.BluetoothInputDevice$2@5cc416f that was originally bound here android.app.ServiceConnectionLeaked: Service com.android.bluetooth.hid.BluetoothAutoPairService has leaked ServiceConnection android.bluetooth.BluetoothInputDevice$2@5cc416f that was originally bound here at android.app.LoadedApk$ServiceDispatcher.<init>(LoadedApk.java:1336) at android.app.LoadedApk.getServiceDispatcher(LoadedApk.java:1231) at android.app.ContextImpl.bindServiceCommon(ContextImpl.java:1450) at android.app.ContextImpl.bindServiceAsUser(ContextImpl.java:1430) at android.content.ContextWrapper.bindServiceAsUser(ContextWrapper.java:643) at android.bluetooth.BluetoothInputDevice.doBind(BluetoothInputDevice.java:262) at android.bluetooth.BluetoothInputDevice.<init>(BluetoothInputDevice.java:255) at android.bluetooth.BluetoothAdapter.getProfileProxy(BluetoothAdapter.java:1909) at com.android.bluetooth.hid.BluetoothAutoPairService.initBt(BluetoothAutoPairService.java:189) at com.android.bluetooth.hid.BluetoothAutoPairService.onHandleIntent(BluetoothAutoPairService.java:53) at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:68) at android.os.Handler.dispatchMessage(Handler.java:102) at android.os.Looper.loop(Looper.java:154) at android.os.HandlerThread.run(HandlerThread.java:61)
Put the Zip file inside the sd card
philippe
Thanks for your help!
Originally posted by Magendanz View Post[*]Recommendations will show in the status bar by design. If you want it always hidden, just uncomment "persist.sys.useTvStatusBar=true" in build.prop.
When I try ES File Explorer I get the message "read only system file"
thanks
I ran it just to test and dpad and touchpad are working fine.
And thanks M for the update.
Originally posted by tenoce View Post
I've found your GT1 remote in zaza! thank you very much!
I need the IR remote to wake the box after power off.
I also use Android TV remote app.
Anyway some strange happens if I use Android TV remote app using my phone.
if my phone is connected to wifi router before the TVbox, the remote app will not found the box.
solution is easy, I just disconnect and reconnect the wifi on my phone, the remote app then will found the box.
There are currently 3616 users online. 0 members and 3616 guests.
