[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Originally posted by lapillo View Post
Beach buggy racing
Of course, I think the GT1 hasen't the same capacity as Nvidia Shield but in fact the game i've tsted working fine.
I hope this help you...
Link for Amazon Prime Video apk for Android TV https://www.google.de/amp/s/toengel....erfuegbar/amp/!
Originally posted by ZZDeZ View Post
Ok, i have tested the game and it works fine for me on my GT1 AX12 device. I have played few races without problem. The game is fluid and sound works fine.
Guest
I think I've got a workaround for the Bluetooth audio stutter on the Longsys LTM8830.
It seems the Shiningworth All-in-One firmware does a runtime check to determine the wireless chipset, then loads a Broadcom (libbt-vendor.so) or Qualcomm (libbt-vendor-qcom.so) Bluetooth vendor library depending on the results. Currently, it's getting the match wrong for the Longsys LTM8830, which is a Qualcomm QCA9377 clone.
To correct this on an affected device:
1. Reboot into TWRP Recovery and mount the System partition.
2. Open TWRP File Manager and delete /system/vendor/lib/libbt-vendor.so.
3. Rename libbt-vendor-qcom.so to libbt-vendor.so.
4. Reboot to System
You shouldn't need to wipe data or cache, and there are no new files needed. It should just load the Qualcomm vendor library from that point on and the audio stutter should be gone.
UPDATE: tillaz87 made a patch here that can be applied in Settings->About-System Update or TWRP recovery.Last edited by Guest; 09 February 2018, 00:36.
Guest I appreciate that but with so many amlogic S912 devices how do actually tell what is a "supported device" I've tried CPU-z app and it doesn't really tell me anything more. Any advice on which ROM to use would be great thanks. All I know about the device is it's called an H96 pro plus with and s912 processor.Last edited by cfour1975; 08 February 2018, 20:39.
Hey Guest
Do you know if the new firmware GT1_ULTIMATE_3GB_32G - GT1_707D0_AP6255 have the same problem (http://www.bee-link.com/Beelink-28438-1-1.html) as tillaz87 Rom (2GB saw instead of 3GB on GT1 ultimate) on your ROM ?
I want to go on a Rom Android TV but as usual, i prepare a rollback because there is so problem on doing this (brick, lag, problem...), i prepare for your Rom or Tillaz's Rom , i dunno yet
By the way, thank you for all your work and the support on This
Cheers
Originally posted by ZZDeZ View PostThank you. I have now two rows after adding more applications.
I have another little question about the name of the device and Spotify : I use spotify on both GT1 devices and choiceI what Iwant to play on what.with my tablet. The problem is that Spotify list the both devices with the same name "Nexus GT1".
Is there a way to change the device name ?
First, I have edited the Build.prop with a program like EsExplorer (Think to activate root accès). I have change the name in the line : ro.product.model=
After that, I have installed from google play a program to use terminal comands called "Terminal Emulator for Android" (it is free).
I run the terminal and first put the command "su" (without quotes) to have root permissions. After that I put the command line to change the device name:
settings put global device_name "<NEW_DEVICE_NAME>"
Now, I have a diferent name on my devices.
There are currently 1629 users online. 2 members and 1627 guests.
