How can I fix it?
[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
my test is ok for my ALFAWISE H96 PRO+ 3G 32G i see on grill my PCB is green for the first time i have tried OTA update rom my menu ota and is not ok there s reboot arrived on screen ON BLACK THAT S WRITE SUPERCELERON LOGO ANDROID but after 30 mn nothing appered ; nothing if i boot in recovery mode then i decided to take USB BURNING TOOLS ok there s detected ok
all is ok for this ROM thanks Superceleron for your job at this moment the BLUETOOTH is ok difficult to research my speaker bluetooth
just prb with my canal there s sound but the image is figed no video
Originally posted by alanjhone View Post
How can I fix it?Attached Files
Originally posted by dangchui View Postmy test is ok for my ALFAWISE H96 PRO+ 3G 32G i see on grill my PCB is green for the first time i have tried OTA update rom my menu ota and is not ok there s reboot arrived on screen ON BLACK THAT S WRITE SUPERCELERON LOGO ANDROID but after 30 mn nothing appered ; nothing if i boot in recovery mode then i decided to take USB BURNING TOOLS ok there s detected ok
Device Beelink gt1, coming from Android TV 6.0 - error in Recovery: Image size is larger then target device. Deleted data, no change. Help please.
yes that s on web site apkpure this link : https://apkpure.com/mycanal-la-tv-by...ails%2Fversion
i that s not functionnal take same procedure at me install first old version 3.2.0.1 first control after install version 3.1.0.35
Originally posted by Magendanz View PostYou can't use the OTA update to go from Marshmallow to Nougat builds, since it needs to repartition the drive. Only option is the burn package with Amlogic's USB Burning Tool or Burn Card Maker.
@Magendanz
When I was looking at your M8S Pro L TV ROM
Noticed that you forgot to delete ExtShared the gapps package adds GoogleExtShared
also noticed play services updates to no atv version com.google.android.gms (440-)
Think you forgot to move CanvasPackageInstaller to /app or sign it with platform key as well as it's not working
Think its same here as well
No sure if you all ready know this but just thought I would say just in case.. tried to PM you this but was always an empty message?
CanvasPackageInstaller is signed with platform key and in /priv-app, the same location it's placed on the Nexus Player, and play services is the latest PrebuiltGmsCorePano from OpenGApps TVStock (Android TV version). You're right that the ExtShared is redundant, though, and I'm surprised that the OpenGApps script didn't remove it when it installed GoogleExtShared.
There are currently 3528 users online. 3 members and 3525 guests.
