[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Originally posted by cbm View PostThe link to the 25/11 OTA is expired. I get the following message Guest " This item might not exist or is no longer available
This item might have been deleted, expired, or you might not have permission to view it. Contact the owner of this item for more information."
Guest
I received my new GT1 Ultimate in the mail yesterday, and I've now tested it with this latest ROM. Unfortunately, I found a 1-byte error in the device tree for the 3GB DRAM configuration that will cause a hang after the boot logo. I've corrected the mistake and am doing an in-place refresh of all the links from the last build, so in a couple of hours everyone should be downloading new copies with the fix.
This rolling update is only for the 3GB DRAM GT1 Ultimate configuration. All others should be unaffected.
Originally posted by Magendanz View PostI received my new GT1 Ultimate in the mail yesterday, and I've now tested it with this latest ROM. Unfortunately, I found a 1-byte error in the device tree for the 3GB DRAM configuration that will cause a hang after the boot logo. I've corrected the mistake and am doing an in-place refresh of all the links from the last build, so in a couple of hours everyone should be downloading new copies with the fix.
Philippe
#396.1Guest commented30 November 2017, 21:05Editing a commentYes, I can confirm that the updated device tree works fine on my 3GB GT1 Ultimate, where before it would hang at the boot logo. I owe thanks to gearbest for the generous hardware donation.
And yes, I'm from 'Merica. Spent 12 years in the U.S. Navy, 20 years at Microsoft, and 4 years as a Washington state representative. I do this for fun. :-)
Originally posted by teters01 View PostI know the cause why the nav bar is missing. If you install a normal apk file the nav bar will disappear when you reboot. And it will not go back even you turn it on from display settings. I think its a bug
Magendanz Is there any boxes you support that have Widevine L1 and would be a better option or is the beelink GT1/Ultimate the best budget box? Thank you
Originally posted by makavelio View PostWhere is best to buy this box and does it do 4k netflix and amazon vidoe? thank you
Its here as well, where i got my remote. these ship crazy fast had the remote in few days.
https://www.geekbuying.com/item/MECO...GB-386123.html
Netflix yes, not sure amazon.
Originally posted by tillaz87 View Post
Got mine here like most china stuff I buy. but they are so slow to ship..
There are currently 1924 users online. 0 members and 1924 guests.
