.gif)
[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Guest
Changelog (20171125):- Fixed Action Bar bug in Settings, and so More Settings is now restored. (Thanks, tillaz87!)
- Removed LED status service and references to supporting controller in the device tree. Should be smoother now.
- Removed battery charge icon from status bar.
- Cleaned up text in Settings->Display, clarifying language and fixing misspellings.
- Latest build from Open GApps (20171125)
- I'm still seeing some stuttering with Bluetooth audio, but it comes and goes.
- Google Cast service broadcasts and is discoverable from mobile devices, but quits unexpectedly when connected.
- Recommendations will show in the status bar by design. If you want it always hidden, just uncomment "persist.sys.useTvStatusBar=true" in build.prop.
- If holding reset button to boot to recovery, release after 10 seconds and then wait for almost a minute. It will eventually get there.
- TVStock Variant: BURN PACKAGE (1.09GB IMG file), OTA UPDATE (569MB ZIP file)
Hi magendanz,
sorry about this basic question but what are the differences between the Rom of this thread and the Rom of the other thread ?
the ÔTA file is 569 MB while in the other one it is 830 Mb with the same content as far as I read
thank you by advance
PHILIPPE
Sorry
whatbis the difference between the OTA update file of this thread and the “stock variant”of this one http://freaktab.com/forum/tv-player-...ms-android-7-1
philippe
Good Morning to all of you!
Magendanz, I installed your OTA (20171125) update (GT1 - qca9377 wifi - 2GB & 32GB) a couple of hours ago. I have no navigation bar despite going to Settings->Display->Toggle Navigation Bar and trying several times the on - off setting. I did also reboots when enabling the on - off settings. Status bar on the other hand is still showinhg up.
Is this intended or am I doing something wrong.
PS I flashed your OTA update trough TWRP
Thanks again for all your work!!!!
Guest
Man, you guys are fast on the download! I had originally included persist.sys.useTvStatusBar=true in the build.prop for the TVStock variant, since that's what's supposed to be used on Android TV. However, I changed my mind after discovering that it not only hid the status bar, but also the navigation bar. An update was posted just 34 minutes later, but I think some of you may have gotten the earlier version.
So, you can refresh your download and run the update again, or you can comment out that line in the build.prop. That's the only change I made.
Guest
They're both based on the Shiningworth All-in-One ROM (Vorke Z6 20171110), but I split them into different releases so that I could do some customization. It turns out that the lack of a LED display on the GT1 was causing some minor performance problems, a slight judder as it was waiting for response from a non-existent FD628 controller.
It is now in brick condition, and I hope to be able to flash with the tool and the img package. The please zip from twrp caused the brick to have been Magisk cause thanks I let you know if it starts.
There are many degrees of "bricked", and I'm hoping this is one that can easily be remedied with a flash from USB Burning Tool. If not, you can always recover in Mask ROM mode, but that requires opening the case.
Also, you can try to reboot to TWRP recovery by powering up with the reset switch depressed. With this bootloader, you've got to hold it for about 10 seconds and then wait an extra minute or so for it to continue. Not sure why it takes so long, but it should get there eventually.
Fortunately it is shared with usb tool. Maybe a thousand, if I had to open the tv box which pin i was going to short my beelink gt1? Thanks Guest
Originally posted by Magendanz View PostMan, you guys are fast on the download! I had originally included persist.sys.useTvStatusBar=true in the build.prop for the TVStock variant, since that's what's supposed to be used on Android TV. However, I changed my mind after discovering that it not only hid the status bar, but also the navigation bar. An update was posted just 34 minutes later, but I think some of you may have gotten the earlier version.
So, you can refresh your download and run the update again, or you can comment out that line in the build.prop. That's the only change I made.Man if your work was'nt that outsatnding and incredible good, I would not mind downloading!!! I visit your thread at least a dozen times a day just to keep up with your pace. Once again, F A N T A S T I C W O R K !!!!!!!!!!!!!!!!!!!!!!!
There are currently 3162 users online. 1 members and 3161 guests.
