[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Originally posted by CHARLUS60 View PostHello I just tested the latest update tv stock rélaiser by Magendanz I found access to the sdcard, but the wi-fi still does not work networks are found but no connection possible, it worked on the stock version ... No evolution concerning the sound still no dts or dollby via plex or kodi. The power button disappeared I use the remote control to turn off the box. I am looking for a solution for the sound via an application, I retrieve an old version of kodi and another of stmc .. Other possible solutions? thank you for your work Charles
I have a gt1 ultimate ax12
Originally posted by Magendanz View PostChangelog (20171108):- New system apps and framework from M8S Pro, but still built on the All-in-One TX8 Max kernel and foundation.
- M8S Pro framework fixed the Action Bar bug in Android TV, as well as the More Settings crash in Android TV.
- Added additional option (Sleep) to global action menu that displays when you press and hold the Power button.
- Fixed Bluetooth audio stuttering problem. (Have confirmed on QCA9377 wireless chipset, but not AP6255.)
- Fixed issue with external storage not showing up in some applications.
- A new set of OEM-specific options are available in Settings, particularly with Display and Dolby/DTS features in Sound.
- Removed attempt to launch voice assist on Back button long press. (Only valid for watches)
- Added support for all HID devices (e.g. remotes, gamepads, etc.) on latest Nougat firmware for Nexus Player, NVIDIA Shield TV & Xiamoi Mi Box
- The Terminal app now shows only after being enabled in Settings->Developer Options.
- Releasing as OTA updates (.zip file) as well as Amlogic burn packages (.img file)
- Latest build from Open GApps (20171108)
- I'm occasionally seeing a stutter in UI animations, but it fortunately doesn't seem to affect video playback.
- Google Cast service broadcasts and is discoverable from mobile devices, but sometimes quits unexpectedly when connected.
- If holding reset button to boot to recovery, release after 10 seconds and then wait for almost a minute. It will eventually get there.
- TVStock Variant: BURN PACKAGE (980MB IMG file), OTA UPDATE (533MB ZIP file)
- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Originally posted by Arnyto View PostHi Magendanz, thank you for this release.
I installed the new OTA version (20171108) on my GT1 A912 and I confirm that bluetooth is not working on A912 version (doesn't turn on).
For me, wifi is working good.
Originally posted by joelkolb View PostGuest have you taken a look at the firmware for the Tanix TX92 as a possible base? It is also running the q201. I don't know if any of the previous issues from the TX8 beta firmware are present but it's a new box that launched with Android 7.1.2 and is on sale now so it's firmware is at least out of beta. Hopefully that means some of the bugs are fixed.
Hi Magendanz, ok to try it if it can't brick my GT1
Thank you
Sorry, I ran into the Bluetooth audio problem again on the TX9 Pro firmware, but it seems to be something I'm doing because I can't reproduce on the unaltered OEM ROM. Unfortunately, I'm catching a flight to Boston for the weekend in a couple of hours, so this may have to wait until Tuesday.
If you're curious, here's what I've got now: https://1drv.ms/u/s!AoqocX31ecnXgadQffOyv0_xnzmy4w
Originally posted by zickler View Post
Guest this is the link for the TX9 Pro firmware. Any idea if we can use your rom on this box since it was previously based on the Tanix TX8?
http://www.tanix-box.com/download-vi...-2-full-image/
Originally posted by GNex5 View Post
Yes, I have this ROM installed on my Beelink GT1 Ultimate. The AIDA64 diagnostic app detects the 3 GB of RAM as expected.
Did someone install this Rom on a beelink gt1 ultimate through update app??? Thanks!!
Originally posted by sweetnonso View Post
Yes it certainly does.
@CHARLUS60 After reading this :
I believe Beelink GT1 is the WORST CRAP S912 box.
For S905X : MIBOX3 (MDZ-16-AB) the best Android TV Box.
For S912 : Minix NEO U9-H the best Android TV Box.
Hi Magendanz,
I have a Mecool KM8 P box in which I have installed this rom. All seems to be working ok, except for Ethernet. I did try your rom for the Mecool m8s pro as well, for which Ethernet did work but Wifi did not (9082c Wifi drivers are missing).
Is there a way to enable ethernet in this rom?
There are currently 1891 users online. 2 members and 1889 guests.
