[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Can someone please share update app apk, I am using first Rom of this thread and it doesn't have that appÂ
#196.1Guest commented17 September 2017, 09:00Editing a commentYou can install the update from TWRP recovery. Just type "reboot recovery" in Terminal, hit Install, select your source (SD card, USB flash drive), select the .zip file, and swipe to install. After you're done, I recommend a Wipe (factory reset), but you might be able to skip that if it's just an incremental update.
I have some issue with wired network.
I got Ip, no prob, Internet Ok (but slow).
When i try to watch video (with Kodi for example), it's buffering each 2 sec, crappy video and desynchronize audio.
With wireless, no prob.
I try some usb networking adptater but no one is detected by Android.
My device is Alfawise S92 Digital (https://www.gearbest.com/tv-box-mini-pc/pp_462430.html)
Great work!! Was waiting for the ATV7 Rom
but there are two differences with the previous 6 Rom.
- no more “wake on USB” support?
Once in sleep mode, it only wakes with IR originals remote, not anymore with the RF USB remote (mine from Rii)
- on google play store, most apps do not display “install” button anymore ...
Do Apps have to be built for TV, or maybe not compatible with 7.1?
Anyway, love this ROM, very stable and smooth
cheers!
Download links are not working both usb burn image and ota(maybe its a problem in my country.. Shows server not working) Can u provide a google drive link.. Guest I am current using GT1 ultimate s/n: AX12 and running on Android 7.1.2 704N0.. Can i flash this using updater directly??? Bro please help me out... The stock rom is just unusable
Sorry, but I went the Google Drive route before and ran into some limits on anonymous downloaders. OneDrive also has these, but I was able to upgrade with my Office365 subscription to eliminate them. I'm just not willing to pay for that twice, or deal with the additional time of uploading to multiple file sharing services. (I have a relatively slow broadband connection.)
I did just verify the OneDrive links for both OTA update and burn package, and they're working fine for me.
Hello and thanks for the rom. The thing is that I want to unroot it. Can anyone suggest a way to unroot?
Originally posted by Magendanz View PostThere's a new build of the Nano and Stock variants today, based on a new OEM firmware foundation. If you like what you see, my plan is to release a TVStock variant tomorrow.
Changelog (20170825):- Now based on TX8 Max OEM firmware (20170815), which apparently has support for both Qualcomm/Longsys and AMPAK/Broadcom wireless chipsets.
- Some new options are available in Settings, particularly with Display and Dolby/DTS features in Sound.
- The navigation bar is back. Just drag up from the bottom to show and hit the chevrons to hide.
- Remote codes are no longer stored in the device tree, so Mouse Mode functionality is restored and you can customize the remote.conf.
- Replaced Jack Palevich's Terminal Emulator with Terminal app from LineageOS, tweaking manifest so that it always shows in launcher.
- Power button press-and-hold now shows both Power Off and Restart. Behavior for short-press is configured in Settings.
- Latest build from Open GApps (20170825)
-> As requested by others users, would be really great to add support for a french physical keyboard (AZERTY)
-> The remote.conf is customizable, good but do you have any clue to enable Kodi or Media Key on my IR remote it does not work even after having changed the code in the file itself.... I'm not getting the event key itself (tested with MKR) - Just one update from today my IR remote is having 2x different factory code, that's the reason why it does not work.... Any clue if it's possible to manage 2x different factory code in one conf file?
Update on 10/10/2017:
1 - Azerty Keyboad can be found here: https://forum.xda-developers.com/sho....php?t=1082408
2 - I found a way with remote.conf as used below:
#this file is configuration for each factory remote device
# work_mode 0 :software mode 1 :hardware mode
# repeat_enable 0 :disable repeat 1 :enable repeat
# factory_code each device has it's unique factory code.
# pattern:custom_code(16bit)+index_code(16bit)
# examble: 0xff000001 = 0xff00(custom cod) 0001 (index)
# release_delay unit:ms.release will report from kernel to user layer after this period of time
# from press or repeat triggered.
# debug_enable 0 :debug disable 1 :debug disable
# SW MODE:
# bit_count how many bits in each frame
# tw_leader_act time window for leader active
# tw_bit0 time window for bit0 time.
# tw_bit1 time window for bit1 time
# tw_repeat_leader time window for repeat leader
# REG
# reg_base_gen set value for PREG_IR_DEC_BASE_GEN
# reg_control set value for PREG_IR_DEC_CONTROL
# reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE
# reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE
# reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE
# reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME
#amlogic NEC remote
work_mode = 0
repeat_enable = 1
repeat_delay = 130
repeat_peroid = 120
release_delay = 20
debug_enable = 1
#fn_key_scancode = 0x15
#left_key_scancode = 0x1c
#right_key_scancode = 0x48
#up_key_scancode = 0x44
#down_key_scancode = 0x1d
#ok_key_scancode = 0x5c
#pageup_key_scancode = 0x04
#pagedown_key_scancode = 0x1b
custom_begin
factory_infcode = 0
factory_code = 0xff000001
fn_key_scancode = 0x5c
left_key_scancode = 0x0e
right_key_scancode = 0x1a
up_key_scancode = 0x03
down_key_scancode = 0x02
ok_key_scancode = 0x07
mouse_begin
0 0x0e
1 0x1a
2 0x03
3 0x02
mouse_end
key_begin
0x14 704
0x48 102
0x5c 63
0x03 103
0x02 108
0x0e 105
0x1a 106
0x07 97
0x13 139
0x01 158
0x58 114
0x0b 115
key_end
repeat_key_begin
0x14 704
0x48 102
0x5c 63
0x03 103
0x02 108
0x0e 105
0x1a 106
0x07 97
0x13 139
0x01 158
0x58 114
0x0b 115
repeat_key_end
custom_end
custom_begin
factory_infcode = 1
factory_code = 0x7f800001
fn_key_scancode = 0x52
left_key_scancode = 0x25
right_key_scancode = 0x27
up_key_scancode = 0x26
down_key_scancode = 0x28
ok_key_scancode = 0x0d
mouse_begin
0 0x25
1 0x27
2 0x26
3 0x28
mouse_end
key_begin
0x4d 113
0x56 114
0x4e 115
0x25 105
0x26 103
0x27 106
0x28 108
0x0d 97
0x1b 158
0x53 102
0x51 704
0x49 139
0x52 63
0x31 2
0x32 3
0x33 4
0x34 5
0x35 6
0x36 7
0x37 8
0x38 9
0x39 10
0x30 11
0x58 288
0x44 14
0xbd 122
0xbb 123
0x09 292
0x11 289
0x54 290
0x4f 291
0xbc 140
0x40 67
0x41 177
0x42 178
key_end
repeat_key_begin
0x4d 113
0x56 114
0x4e 115
0x25 105
0x26 103
0x27 106
0x28 108
0x0d 97
0x1b 158
0x53 102
0x51 704
0x49 139
0x52 63
0x31 2
0x32 3
0x33 4
0x34 5
0x35 6
0x36 7
0x37 8
0x38 9
0x39 10
0x30 11
0x58 288
0x44 14
0xbd 122
0xbb 123
0x09 292
0x11 289
0x54 290
0x4f 291
0xbc 140
0x40 67
0x41 177
0x42 178
repeat_key_end
custom_end
There are currently 3862 users online. 0 members and 3862 guests.
