[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Originally posted by tillaz87 View Post
did you uninstall app and reinstall ? I remember seeing people on beelink forum saying the userdebug was causing iptv apps not to work. i personly never had a problem but i use perfect player
Originally posted by jeanlouis View Post
Yes i have reinstall the app, it's a problem concerning the mac adress, this app use the mac adress for send the .m3u playlist on the box, the connection is not made between the two
@Magendanz
Your other rom (in android 7) " Beelink GT1 / Alfawise S92 Stock & Nano Nexus ROMs (Android 7.1)" has the same problem (SdCard not recognized in EsExplorer / Usb stick not présent in Kodi)
So what can we do ? (i usually use local storage to watch movies)
Can i go back to Marshmallow with TRWP or bootcardMaker ? (i've got an error when i try with bootcardmaker , i think because downgrading version )
Guest I have been flashing away all other ATV 7.1 versions present in this forum none seem to have the USB/SD Card issue, including the TX8 version which you suggested.
Originally posted by sunwk View PostAnyone having trouble playing ac3 format video files with Plex? I was able to play anything with Plex before when I was on ATV 6 rom before, but after upgrading to ATV 7, Plex has no sound for all ac3 format video files, including ts, mkv. Plex plays DTS with sound, but not with ac3. KODI/SPMC has no problem playing the same files.
Guest
Originally posted by zickler View PostGuest I have been flashing away all other ATV 7.1 versions present in this forum none seem to have the USB/SD Card issue, including the TX8 version which you suggested.
Are you seeing this problem in the Nano or Stock variant?
Originally posted by Magendanz View PostIf that's the case, then I should be able to see SOMETHING different when I compare the two /etc directories. I've even compared the file/folder permissions, and they're identical.
If you go to /storage, SD card is listed as <media_id> but you can't access to SD content. (nothing is displayed and no write access)
If you go to /mnt/media_rw/<media_id>, it works fine and you can access to all information stored in your SD card and copy some content. (you can install apk file for example)
But a lot of applications seem to look first to /storage location and as they find it they use this wrong link. (X-plore displays the good one by default)
I'm using Apps2SD to extend natively device storage but it seems to use also this wrong location and I haven't find yet how to specify an alternate location.
There are currently 2301 users online. 0 members and 2301 guests.
