[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Originally posted by ZIOLele1980 View Post
well the remote hasn't enough buttons to map all functions i need,.. plus i kinda feel like i wanna play a bit.... i've read in another thread that it's possible to use also rc scan codes is that true? if so, do you know how to switch mode ?
Originally posted by GNex5 View Post
I'm not as technically skilled as you are, to be honest, which means that I don't know how to do what you mentioned at the end. Is it fairly easy?
* Magisk v13.3 Installer
- Mounting /system, /vendor, /cache, /data
- Device platform: arm
! Unable to detect boot image
Updater process ended with ERROR: 1
Error installing zip file '/sdcard/Download/Magisk-v13.3.zip'
Updating partition details...
...done
I am debugging the installer. Open the script META-INF\com\google\android\update-binary
Line 82 and 83 you'll find this:
Code:find_boot_image [ -z $BOOTIMAGE ] && abort "! Unable to detect boot image"
find_boot_image
#[ -z $BOOTIMAGE ] && abort "! Unable to detect boot image"[/CODE]
The installer will skip the ending condition, and script will continue but it don't solve the problem because some lines after (line 151):
Code:ui_print "- Found Boot Image: $BOOTIMAGE"
- Found Boot Image:
The variable $BOOTIMAGE show nothing! It mean it's not set...
If you check the util_functions.sh script you'll find this:
Code:find_boot_image() { if [ -z "$BOOTIMAGE" ]; then for BLOCK in boot_a BOOT_A kern-a KERN-A android_boot ANDROID_BOOT kernel KERNEL boot BOOT lnx LNX; do BOOTIMAGE=`ls /dev/block/by-name/$BLOCK || ls /dev/block/platform/*/by-name/$BLOCK || ls /dev/block/platform/*/*/by-name/$BLOCK` 2>/dev/null [ ! -z $BOOTIMAGE ] && break done fi # Recovery fallback if [ -z "$BOOTIMAGE" ]; then for FSTAB in /etc/*fstab*; do BOOTIMAGE=`grep -E '\b/boot\b' $FSTAB | grep -v "#" | grep -oE '/dev/[a-zA-Z0-9_./-]*'` [ ! -z $BOOTIMAGE ] && break done fi [ -L "$BOOTIMAGE" ] && BOOTIMAGE=`readlink $BOOTIMAGE` }
Can you tell me what is the name of this file?
#48.1Guest commented05 August 2017, 22:10Editing a commentYeah, the problem is that some kernel command lines for Nougat are including "androidboot.slot_suffix=_a" which is confusing install scripts like OpenGApps and Magisk into detecting an A/B partition layout, which they're not using. I've notified VideoStrong of the problem, but need to let Netxeon know too.
To check the kernel command line on a box, just type "cat /proc/cmdline" in the terminal emulator.
Oh, and the boot partition on Amlogic devices is just //dev/block/boot.
Originally posted by mrdigit420 View Post
You can used xposedaddition app that is usable with xposed framework. I have been using it for a while, this app supports external devices. I use with mx3 air mouse with custom shortcuts with keyboard and other buttons. It also supports ir remote
https://github.com/rovo89/Xposed/iss...ment-316085447
"As you already mentioned, your changes could only work for ROMs compiled from scratch with Xposed already active, so people should understand that this won't work (at least not reliably) on their stock or otherwise pre-compiled ROMs."
https://github.com/rovo89/Xposed/iss...ment-316623920
"Their code is abforce's port, with all the limitations I listed above. It doesn't make sense at all to publish flashable ZIPs with this, as the port is only intended for recompiling a ROM from scratch. And as I feared, there is not a single warning that this is an incomplete port that will often fail to fulfill the API contract. That's bad for developers and users, they should at least know it's incomplete so they can decide whether they want to support/use it. I would never dare to do something like that without a big fat warning. Actually, as I'm rather perfectionist, I wouldn't publish an incomplete version at all, reliablity is very important for me."
It's unlikely that Magendanz would release a custom ROM with Xposed Framework built in. Doing so would go against his statement in the first post.
"The goal is to keep true to Google's vision and use the bare minimum of OEM or third-party apps or add-ons, which can be added à la carte by the user as needed, just as I've done with the Stock and Nano variants."Last edited by GNex5; 05 August 2017, 16:39.
Xposed Framework is not yet (officially) compatible with Android 7.x Nougat. Here are rovo89's comments on the unofficial Xposed port for Nougat that made news recently.
Also if anyone interested in alternate or shortcut to Leanback launcher, check this https://github.com/itvlab/tvapprepo/releasesLast edited by mrdigit420; 06 August 2017, 12:34.
Thanks,
Well, there appears to be no documentation on this other than what's in the Amlogic SDK 7.1, but unfortunately we don't have access to that. I did find this: http://www.cnx-software.com/2017/03/...st-quick-look/
Guest
I'm afraid that I've got some bad news to report on the Mouse Mode bug. I've spent the last 12 hours working on a fix, and I'm still at an impasse. In the old remote.conf files that were used in Marshmallow and earlier for mapping remote scan codes, you just set "fn_key_scancode" to the scan code for the Mouse Mode button and were done with it. And while the remote keymaps have moved to the device tree in Nougat, there's no documentation on where the equivalent of "fn_key_scancode" is now stored. Looking through the device tree, nothing obvious stands out.
Setting the keymap entry for the scan code so that it produces the same key code as the old remote has no effect, so it appears they're pulling the setting from somewhere else. It's not clear where, and so at this point I'm referring the problem to someone with more inside knowledge of the Amlogic SDK 7.1. We could be waiting a while.
Guest I'm curious about how you were able to package this ROM. Was a new Amlogic customization tool for Nougat finally released. I've search all over but I haven't been able to find anything.
Originally posted by Alex06 View Post
Hi, I have the same problem when I try to install Magisk 13.3 from zip in TWRP. It stop at this message:
...done
find_boot_image
- Found Boot Image:
replace this:
Code:BOOTIMAGE=`ls /dev/block/by-name/$BLOCK || ls /dev/block/platform/*/by-name/$BLOCK || ls /dev/block/platform/*/*/by-name/$BLOCK` 2>/dev/null
Code:BOOTIMAGE=`ls /dev/block/$BLOCK || ls /dev/block/platform/*/by-name/$BLOCK || ls /dev/block/platform/*/*/by-name/$BLOCK` 2>/dev/null
Originally posted by Alex06 View PostI found an other bug, maybe known? With HDMI-CEC activated, at first boot or sleep exit the TV remote is not detected by the TV Box, you have to switch to TV then HDMI to make the TV remote operate again.
Hi Magendanz,
Can you confirm that rom is the same as Mini M8S Pro?
Since I tested on the Ultimate GT1 and it is ok to me, both on GT1 (QCA9377) and GT ultimate (QCA9377) and since the MIni MXIII 2 shares the same Rom with the Mini M8S on the S912 chip will it be the same?
Best Regards
There are currently 1592 users online. 0 members and 1592 guests.
