[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
    Sleep mode is not working properly.
    After 1st boot, it works well, but after waken for 3~5 times, it sleeps deeply, it doesn't wake..
    Someone has issue like me?
    and I have some solution about magisk
    there is v13.6 beta.
    this version is installed without any edit.
    Hello, welcome to the beta Magisk thread! First check the main thread before starting. I expect users reporting to at least have basic debug skills, this thread is heavily moderated so refrain from spamming with "useless" reports! Latest Magisk...
      In mine is the same, so I always turn off.
      Will be corrected in the next update
        Hi
        When is the AMPAK wifi module going to be available?
        • Guest's Avatar
          Guest commented
          Editing a comment
          I've got about four projects ahead of it in the queue.
        #79
        Please solve the google cast problem
        • Guest's Avatar
          Guest commented
          Editing a comment
          Are you aware of any fix for Google Cast on these boxes (other than getting Widevine L1 certified)? I'm not.
        #80
        Hi there,
        I'm considering to install your rom using the usb/usb cable but i'm wondering if we need to uncheck the "erase bootloader" option or not.
        waiting for your confirmation
        Thanks !
        • Guest's Avatar
          Guest commented
          Editing a comment
          I never do, but it's a prudent precaution.
        #81
        So you confirm it's better to uncheck it.
        Edit : Installed the ROM on GT1 Ultimate, works better than expected.
        Many thanks again for what you're doing for all of us.
          There's a new build of the Nano and Stock variants today, based on a new OEM firmware foundation. If you like what you see, my plan is to release a TVStock variant tomorrow.
          Changelog (20170825):
          • Now based on TX8 Max OEM firmware (20170815), which apparently has support for both Qualcomm/Longsys and AMPAK/Broadcom wireless chipsets.
          • Some new options are available in Settings, particularly with Display and Dolby/DTS features in Sound.
          • The navigation bar is back. Just drag up from the bottom to show and hit the chevrons to hide.
          • Remote codes are no longer stored in the device tree, so Mouse Mode functionality is restored and you can customize the remote.conf.
          • Replaced Jack Palevich's Terminal Emulator with Terminal app from LineageOS, tweaking manifest so that it always shows in launcher.
          • Power button press-and-hold now shows both Power Off and Restart. Behavior for short-press is configured in Settings.
          • Latest build from Open GApps (20170825)
            Hello anyone use gamestream (moonlight) with this fw? Works fine?
              how different is this from tillaz 7.1.x ATV release?
              (thanks for the work you do)
                Okay, I've just updated the link for this new build based on the TX8 Max OEM firmware. There's a lot to love about this new ROM, but the one big known issue is Bluetooth audio. If you use that heavily, you might want to hold off on this release. I'm hoping that the issue is addressed soon, because it's pretty unusable in its present state.
                  Gonna have to try this one, I like the android tv, I once hated it, but it grew on me.
                    Just installed, and trying to configure the system.
                    But, when in play store I cannot search for nothing, since when I press the search icon, it returns to Home srcreen.
                    So I cannot install nothing from Play Store.
                    Also, I cannot install apk files. But, installation from unknown sources is selected.
                    Can this be fixed? thanks.
                    • Guest's Avatar
                      Guest commented
                      Editing a comment
                      Yes, I found the bug with search on TVStock. (I took a newer version of Katniss from Fugu, and it had an x86 lib.) A fix is forthcoming.
                    #88
                    Thank you.
                    And, what about the apk files: i cannot install them; i click on them but nothing happens.
                    This Rom has auto-update? Or I must be with attention for the updates and manually install them?
                    • Guest's Avatar
                      Guest commented
                      Editing a comment
                      I think that's a related problem, but I'm confirming now.
                      Where are you clicking on the .apk files? Is it the Chrome browser? Or the Downloads app? This is working for me.
                    #89
                    I'm clicking on Transferred files.
                    • Guest's Avatar
                      Guest commented
                      Editing a comment
                      Where's that?
                    #90
                    Ok, sorry, my translation was bad.
                    I downloaded the files through Chrome, so its on default Downloads folder. After, I use the app Files, if i'm not mistaken. It's ll with the native apps after install, since I cannot install apps from Play Store. Hope this helps.
