Should I download the file to sdcard, reboot to twrp (how do I reboot to recover??), and install zip?
[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Ok, I've done it, and it fixed the fact I couldn't write in search in Play Store, for example.
But, I still can't install apk files!
should I try install other file manager from play store and try that way?
This is very strange, since it's working for me when I open .apks from the built-in Files app and Chrome.
Okay, I'm reverting both CanvasPackageInstaller and GooglePackageInstaller to the previous versions. We'll see if that helps.Last edited by Guest; 28 August 2017, 23:18.
Originally posted by gt85nz View Postgreat work with the rom love it ,,, are you going to enable recent apps ? doubble press home i think ?? maby assistant in future
Guest
If you didn't pick this up from earlier comments, I picked up a couple of bugs when I grabbed newer versions of Google Search (Katniss) and the Android TV Package Installer (CanvasPackageInstaller) from the latest factory ROMs posted for the Nexus Player. I've since reverted to the previous versions, and it seems to have fixed the issues.
Since I was a bit time constrained, there was no new official release. If you use the old links, you'll pick up the changes.
I've also added an OTA update, which can be flashed in TWRP without need for a data wipe.
Originally posted by Magendanz View PostIf you didn't pick this up from earlier comments, I picked up a couple of bugs when I grabbed newer versions of Google Search (Katniss) and the Android TV Package Installer (CanvasPackageInstaller) from the latest factory ROMs posted for the Nexus Player. I've since reverted to the previous versions, and it seems to have fixed the issues.
Does this needs to be fixed? How to do it? Is this a major problem?
No, that setting just erases the bootloader before flashing the new bootloader.img. It's prudent to uncheck the box, just in case something happens between the erase and write, but it's a very small time window for something to go wrong. On the other hand, if it does you'll need to reset to Mask ROM mode by shorting pins on the eMMC, so why risk it?
@Magendanz
I confirm the OTA update fixed the search problem for play store. I notice there is a slight delay for audio when playing a live tv stream. I don't experience the problem for your Android TV 6.0 ROM.
By the way, can you add the following in the init.amlogic.board.rc for init.d support? It is very helpful to run some init scripts when the system booted up.
service sysinit /system/xbin/busybox run-parts /system/etc/init.d
user root
group root
class main
oneshot
WiFi did not work initially, at the initial setup it wouldn't connect. It would say connected successfully but when at sign in page, it would say network issue then retype the password and redo connection. I then installed OTA through recovery thinking it would fix the issue but it did not. I then used ethernet to setup the device then after few tries I was able to connect to wifi. So I am not sure what was the issue there. S92 Alfawise here btw
Just to be clear, you can choose to flash using the burn package (.img file) or OTA update (.zip file), but it would be entirely redundant to do both. Of the two, I prefer the burn package because you get a "clean install" and will resolve any partitioning issues. It also won't work on the wrong hardware (which may not be true of the OTA update).
As for WiFi, some of these chipsets take a while to connect and get an IP. That's especially true with a weak signal, and the internal antennas on these are crap.
Originally posted by jotascotch View PostSo, I must install OTA again?
Thank you.
Now i'm figuring out how to personalize some things.
How do we put app shortcuts on the Homescreen?
This website makes shortcuts (very small APK's) so you can launch your apps from you home screen: http://atvlauncher.trekgonewild.de
Just follow the instructions on the site and you can make custom shortcuts and use your own graphics.
Hi Magendanz, is it possible to upgrade via OTA from your version update_GT1_113M0_TVStock-20170606?
If yes, will i lose all my apps?
Thank you
There are currently 1883 users online. 0 members and 1883 guests.
