[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Originally posted by Magendanz View Post
#346.1Guest commented24 November 2017, 03:42Editing a commentI didn't bother because I didn't think it was accessible. These new Shiningworth ROMs hide More Settings on the ATV builds, and the VideoStrong ROMs don't have this problem.Last edited by Guest; 24 November 2017, 04:21.
Yep, I didn't count on people clicking through from the status bar. Just forgot about that entry point. Also, this fix was supposedly checked into the Shiningworth source, so I didn't think the newer releases would have the Settings crash.Last edited by Guest; 24 November 2017, 04:23.
So, the fix used for settings.apk in the M8S firmware is
Decomplle settings.apk
res\layout-television-v8\settings_with_drawer.xml
open settings_with_drawer.xml delete all code and paste this inside and save. (ids are already in public.xml)
Code:<?xml version="1.0" encoding="utf-8"?> <android.support.v4.widget.DrawerLayout android:id="@id/drawer_layout" android:background="?android:colorPrimaryDark" android:layout_width="fill_parent" android:layout_height="fill_parent" xmlns:android="http://schemas.android.com/apk/res/android"> <LinearLayout android:orientation="vertical" android:id="@id/content_parent" android:fitsSystemWindows="true" android:layout_width="fill_parent" android:layout_height="fill_parent"> <FrameLayout android:layout_width="fill_parent" android:layout_height="wrap_content" style="?android:attr/actionBarStyle"> <Toolbar android:theme="?android:actionBarTheme" android:id="@id/action_bar" android:background="?android:colorPrimary" android:layout_width="fill_parent" android:layout_height="wrap_content" android:navigationContentDescription="@android:string/action_menu_overflow_description" style="?android:attr/toolbarStyle" xmlns:android="http://schemas.android.com/apk/res/android" /> </FrameLayout> <FrameLayout android:id="@id/content_header_container" android:layout_width="fill_parent" android:layout_height="wrap_content" style="?android:attr/actionBarStyle" /> <FrameLayout android:id="@id/content_frame" android:background="?android:windowBackground" android:layout_width="fill_parent" android:layout_height="fill_parent" /> </LinearLayout> <ListView android:layout_gravity="start" android:id="@id/left_drawer" android:background="?android:colorBackground" android:layout_width="300.0dip" android:layout_height="fill_parent" android:divider="@android:color/transparent" android:dividerHeight="0.0dip" android:choiceMode="singleChoice" /> </android.support.v4.widget.DrawerLayout>
attached file here settings_with_drawer.zip (extract)
The ATV action bar bug seems to be by choice in AOSP for some reason
to fix decompile framework-res.apk
res\values-television-v8\bools.xml
change
Code:<bool name="config_defaultWindowFeatureOptionsPanel">false</bool>
Code:<bool name="config_defaultWindowFeatureOptionsPanel">true</bool>
here is a zip to flash since someone asked
adds more settings option back to TVsettings and fixes the crash. this OEM firmware already has action bar fix appliedAttached Files
Originally posted by tillaz87 View PostSo, the fix used for settings.apk in the M8S firmware is
change
Hi everyone,
I'm new to this forum, I want to thank Magendaz's great job, this ROM works very well, I wanted to ask you a couple of questions, my box: Beelink GT1 Ultimate (G912)
1 - on what build is based (705N0 or 707N0)?
2 - in theory that WiFi Chip mounts? Qualcomm QCA9377 or Longsys LTM8830
3 - App Netflix does not start from error code: ui-800-3 (207003), it seems like a root permissions problem, can it be solved?
Thanks again for the great work you've done on these Android-TV ROMs I love!!!
While I did some prerelease builds on GT1_705N0 as an experiment, all my recent releases have been on the Shiningworth All-in-One ROMs for Amlogic q021 reference boards (Tanix and Vorke being some of their OEMs). These have the advantage of having support for multiple wireless chipsets (including Qualcomm QCA9377, Longsys LTM8830 or AMPAK AP6255 and many others), DRAM configurations and IR remotes, which simplifies my release efforts considerably.
The Netflix app error you're seeing is due to lack of Widevine L1 support. I can't fix this, as the secure keys are flashed at the factory and they're not sharing.
Best Beelink GT1 ultimate ROM ever Guest ...everything from 3D to Wi-Fi works great. It's the only ROM I haven't reflashed in about two weeks except when adding the ota, and this made it even better.
Works great for Kodi 18 Leia alpha too...even supports the ATV recommendations from the kodi library.
Always looking forward to more ATV feature additions.
Great work man
Magendanz , very nice work of yours, incredible. Great fan of your work! How would I enter the twrp revovery? Could you please also post a link to get the supersu zip? I need the device (GT1 - qca9377 wifi) rooted!
Greetings do any of your roms work on ultimate with sn AX12GSKF80039 and have a bar in the botom and can play Netflix (SD is ok)?
There are currently 3115 users online. 3 members and 3112 guests.
