[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Originally posted by Yugo79 View PostWith l of 25.11 after the twrp flash reboot nexus written system and then black screen. It went brick can be Magisk the cause? Thanks
Originally posted by sweetnonso View Post
Has anyone else with Magisk flashed this OTA Zip? I flashed the 19/11 last week and got my box soft bricked. Had to use burn package to recover it. Too much hassles setting up the box all over again. Is there way to use OTA with Magisk without soft bricking please?
You should try removing the Magisk root and then flashing the zip from twrp hoping it's ok
Originally posted by cbm View PostThe link to the 25/11 OTA is expired. I get the following message Guest " This item might not exist or is no longer available
This item might have been deleted, expired, or you might not have permission to view it. Contact the owner of this item for more information."
Magendanz Thank you I wanted to try with the download ota the previous page but the link does not work. Would you like to share it in the response message? Thanks a lot for good work
Both OneDrive links from the original post just worked fine for me. I even tested on my wife's machine with an anonymous login. If you're still having trouble, you can try the archive site at http://freaktab.org/4~f. I'm copying the latest builds up there now.
Hello, I can’t find how to start terminal app in order to reboot in twrp and install ota update. Where can I find the app?
The update link on page 25 does not work. The start page is ok but there is no active navigation bar in that update link. Sorry for my English.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
There are currently 2792 users online. 0 members and 2792 guests.
