[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Hi Magendanz,
Just installed your latest rom on GT1 G912 - works great.
Some issues I found:
1) I noticed, do not know if it is related to the rom or just app incompatibility: In some apps (example bbcIplayer) the remote does not work at all. I can only use app with a USB mouse.
2) Try to use twrp to backup to usb. I got this error:
I:Error adding file '/system/app/AppDrawer/AppDrawer.apk' to '/usb-otg/TWRP/BACKUPS/q201/2014-12-31--18-18-19_q201-userdebug_7.1.2_NHG47L_20171110_test-k/system.ext4.win'
Error creating backup.
I:ERROR tarList for thread ID 0
In the past I had no problems doing this.
3) When using beelink rom, I was able to boot twrp from USB stick by putting twrp image (renaming it recovery.img) and dummy update (update.zip) and selecting to update using dummy update.zip. Now when I try to do this - the system displays the logo and hangs forever.
4) Remote power off button just turns the display to black. Original beelink version gave you 3 options (power off, reboot, sleep) when pressing power button.
Thanks again for all your work.
TX,
AlonLast edited by alongilad; 05 December 2017, 15:02.
1. This just seems to be an app incompatibility. Ones not designed for Android TV are sometimes not going to respond to the IR remote keycodes.
2. That's the first I've seen of that bug. It makes me wonder about your storage media.
3. Yes, that's by design. You configure the Power short-press behavior in Settings->Powerkey Definition, which by default is Sleep. Long press will get you the global action menu. (The VideoStrong ROMs offer Power Off, Reboot and Sleep. Shiningworth only gives you Power Off and Restart.)
Hello Magendanz!!!I found several bugs.
1. Turn off the bluetooth.after rebooting the TV box, the bluetooth again included!
2. Great problems with the keyboard configuration.the physical keyboard is not connected.but in the settings in the "physical keyboard" section-all virtual keyboards are displayed.because of this when I connect a physical keyboard-I can not add an additional keyboard layout.
sorry for bad English
You may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by serg1d; 07 December 2017, 13:19.
Originally posted by Magendanz View PostI received my new GT1 Ultimate in the mail yesterday, and I've now tested it with this latest ROM. Unfortunately, I found a 1-byte error in the device tree for the 3GB DRAM configuration that will cause a hang after the boot logo. I've corrected the mistake and am doing an in-place refresh of all the links from the last build, so in a couple of hours everyone should be downloading new copies with the fix.
This rolling update is only for the 3GB DRAM GT1 Ultimate configuration. All others should be unaffected.
I am asking you this because I wonder if your ROM can fit 100% in all GT1 ultimate devices, since I think they differ in hardware, according to the serial numbers.
The new one is an AX12, with the AMPAK AP6255 wireless chipset. However, the Shiningworth All-in-One ROMs have support for many different wireless chipsets, including AMPAK AP6255, Qualcomm QCA9377 & Longsys LTM8830.
The issue I discovered with the device tree was in /meson-fb/logo_addr for the gxm_q201_3g, so it should affect all 3GB DRAM configs.
Hi Magendanz I've just installed this ROM onto an EgoIggo S12 and it works really well, very smooth and looks WAAAAAY better than original ROM. I've noticed that some apps I was able to use before are now longer compatible such as Dropbox and Google Drive. Not a huge issue but worth mentioning. The OTA update on the first post, is this something I need to use or is it just a repackaged version of the image file?
Thanks for your great work.
Yes, some apps designed for mobile (non-ATV) won't work in the Android TV environment, and there's not always ATV equivalents in the ATV Play Store. If you want to run on a mobile (non-ATV) environment, you should check out the Stock and Nano variants of this ROM.
And yes, the OTA update (.zip file) is the same release packaged so that it can be updated from Settings->About->System Update, stock recovery, or TWRP.
There are currently 2430 users online. 0 members and 2430 guests.
