[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
#511.1Guest commented10 January 2018, 22:57Editing a commentOkay, I don't have a DTB for that yet, so it's defaulting to the gxm-q201-2g.dtb. Obviously, that's not right, but since that logic is in the bootloader I may be hard pressed to fix it. The gxm-q201-3g.dtb in the GT1_706D0 is actually identical to the previous releases, and I was expecting to see some differences.
Hi!
First of all, I would like to thank you for the great ROM, Guest!
I got the 3/32 version of the box in December, SN begins with A706. I updated the device by OTA Update. It just works fine, although I'm experiencing the same issue, it says it has only 2 GB of RAM.
I haven't had the chance to try the burn package if it could make it different.
Hi Magendanz,
Excellent work, I would like to thank you for the great ROM,
I got the 2/16 standard GT1 version of the box in December, 2016 and had used 106 unroot version of Beelink.
It was a small problem with app TV channel Magio in this Android TV 7.1 rom (device is rooted), but after deleting su app in system/xbin works now well.
All the best,
BabjakLast edited by anton.babjak; 14 January 2018, 18:27.
Originally posted by VeroKi View PostHi all!!!
Has anyone tested on GT1 Ultimate 3/32 but with serial number beginning by A706?
Please, I wish to offer it to my daddy for Christmas and I'm unable to find something fitting!!!
Thanks in advance for your help!!!
VeroKi
Well i was able to get the ps3 gamepad working by loading the hid-sony.ko kernel module you already included in system/lib/modules
using insmod in terminal
Thank you
Guest
Hi !
Thx for the job and Sorry for my English.
If i understand well, your ROM is a pure android TV and Tillaz87 's ROM patch the beelink android 7.1.2 firmware ?
Where do you put .zip files for OTA Update ?
Is it OK with my GT1U A706D0 ?
If I want to go back to the 707DO firmware can I reput it with SDcard after ?
I can't use USB cable (I do not have the right cable and i'm under OSx so no burning tool).
It's a lot of questions but may be it could help others
Thank you very much.
You can always flash back. However, I don't have explicit support for the new 70xD hardware variant of the GT1 Ultimate. For some reason, it maps to the 2G DTB, so you lose access to a GB of DRAM. Since DTBs in the OEM firmware don't appear to have changed, I'm at a loss to determine how I should properly detect the new hardware.
There are currently 3133 users online. 0 members and 3133 guests.
