[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Guest will this rom work in the new Beelink GT1 Ultimate S/N B706? I'm affraid of updating and brick something since I got it yesterday... natinusala have you found something about this s/n? or tested this rom without problems?
im going to change from supercelerom (android tv android 6.0) as it doesn't update. Hear many good things about this nexus.
My GT1 is s/n A912 AP6255 with 2/16 according to the description seems that this nexus will work.
Any isues i should be aware off, like wifi, airmouse, etc
To install just put the burn image (1.1 gb)
And later flash the ota via twrp?
Many thanks for your work. You deserve a coffee
Guest @natinusala
first thanks for this amazing rom....best and fastest rom i try in my gt1 uiltmate
jigga2g
for fix this problem
download this app service disabler
https://play.google.com/store/apps/d...disabler&hl=ar
than go from app and choose system than Landback Launcher
than press in app and choose disable than direct nova launcher he well be primary launcher
Guest @natinusala
Originally posted by limonetNo one can confirm if everything works on A912 AP6255
MANY THANKS Guest . This rom runs so smooth and snappy in comparation with the other 2 android tv I had tested. I am delighted and will contribute to a coffee. You deserve.
There is one thing . Even tho i installed the burn via sdcard burn and then the OTA ( select wipe data and cache in the updater) and twrp installed it ok, in the system info still shows as 20171221 instead of 20180119
Edit: i think i undestand now. It is because its based on de borke z6 20171221.so will show that and not the ota date
Originally posted by PhilbraHi
if your box is routed, install Amlogic program and you will have a menu to reboot in different modes
or unplug the box, tick the reset button with a toothpick, plug the power, wait one second and release the toothpick and wait for twrp menu
...and don�t make dangerous actions !
phil
Will like to have a method to reboot into twrp other than the pin.
Many thanks
Edit. Ok I had found it. Thanks anywayLast edited by Limonnet; 24 June 2018, 21:55.
There are currently 2456 users online. 0 members and 2456 guests.
