[ROM] Beelink GT1 / Alfawise S92 TVStock Nexus ROM (Android TV 7.1)
Originally posted by Rani2add View PostHow can I use trwp to install it via sdcard?
if your box is routed, install Amlogic program and you will have a menu to reboot in different modes
or unplug the box, tick the reset button with a toothpick, plug the power, wait one second and release the toothpick and wait for twrp menu
...and don’t make dangerous actions !
phil
Hello guys,
I have a mini m8s pro (s912, 2gb, 16gb) which is meant to be the same as a gt1 so I flashed this promising rom but on my box it's really slow and crashes all the time. Even ethernet does'nt work. I first used the OTA method and then used the sd card method thinking it would be better but it didn't change anything. Does anyone have the same problems? I found nothing like that in this thread.
Thanks for your help.
I installed this firmware on my GT1 A912 Box. It is fantastic to have pure AndroidTV experience that feels nature to Remote and Android TV Remote App.
I am not sure why OP said casting is not working. Actually you can link your Android phone to Box's YouTube app and cast videos. Obviously it's for YouTube only but that fits 90% of my casting need. You do need to launch YouTube app on TV box so casting can see it.
Thanks OP so much for such a great Rom, it's so much better than any official Roms from Beelink.
eruisiLast edited by eruisi; 31 December 2017, 23:50.
Originally posted by djlink View PostDid anyone get root? Share the instruction please.
#1 Enable the "local terminal" in Settings->Developer options. If that option isn't visible yet, you can show it by clicking 7 times on Settings->About->Build
#2 Open Terminal Emulator and type "reboot recovery"
#3 (On PC) Download latest magisk from http://tiny.cc/latestmagisk
#4 (On PC) Copy downloaded zip file from step #3 (i.e. "Magisk-v15.1.zip") to USB stick and insert it to Beelink
#5 In TWRP recovery select "Flash zip" and select file from USB stick
#6 After succesfull flashing select reboot and you're done
If any question please ask.
Originally posted by djlink View PostI tried. Magisk can't install root. Unable to detect boot image
I used "Magisk-v14.0.zip" and it worked without problem. May be newer version of Magisk has issue with our device. Also you can try to install su - someone might help you with this process.
Regarding Youtube casting, you can link in Android Youtube app (Setting->Watch on TV to pair) to GT1 Youtube app then cast videos from your phone/pad.
The difference from Chromecast is that you need to launch Youtube app on GT1 first, then your phone/pad Youtube app can see GT1 device to cast. For chromecast, the Youtube casting on phone/pad can launch the Youtube app on Chromecast so a little easier. But what we have on GT1 is already very good to me!
Hello,
Thank you for your job, this is the only rom I can install, others brick the box.
I installed the rom on my new Gt1 Ultimate, it's work great but I have 2 questions/problems
first, I only see 2gb of ram, my box have 3gb. It's normal ?
Second, when the box go in sleep mode (or screen off), all is fine but after time (maybe 15 minutes after entering in sleep mode), usb and optical output seems to be off. I can't wake up box with remote or keyboard. If I wait 5 minutes after the sleep/screen off, I can wake up the box with remote or keyboard normally.
I don't know if the box shutdown after time or simply freezing. For waking up / restart, I need to unplug/plug the power cable.
Any clue ?
Any clue ?
i just clicked the link http://www.bee-link.com/Beelink-27615-1-1.html and some alert 421 window pop-up showed up (virus or something) ?
There are currently 4409 users online. 0 members and 4409 guests.
