Sent from my UMI X2 using Tapatalk 4
Pipo M6 4.2.2 RileyROM 1.5 [SDK 2.0] - [Feedback]
Re: Pipo M6 4.2.2 RileyROM 1.5 [SDK 2.0] - [Feedback]
Originally posted by pulsar123 View PostSo 1.6 will go back to SDK 1.0? That's becoming really confusing.
Originally posted by Batfink32 View PostGuys,
I took the latest chinese img and unpacked it and extracted the kernel (kernel version 49 Sat Jul 27) i then added it to your 1.5 Rom Randy (I think you had an earlier kernel version,36?) I think im getting a pretty snappy Rom with this combination. Do the kernel updates update the speed and snappiness or is this just placebo?
I'm trying to learn how to unpack this stuff without luck. Care to share how you did it, what tool did you use to unpack? Thanks man.
If you still don't have CWM here is my post:http://www.freaktab.com/showthread.p...or-Pipo-Max-M6
Originally posted by Batfink32 View PostHere is the link, use Wendals Rockchip tools http://www.rockchipfirmware.com/developer-tools The tools for the earlier Rockchips will work for the RK3188
It is the same kernel that is in my 1.6 ROM I posted today.
RandyRandy
Wow, I've been away for a few days and 2 versions have almost skipped past me! Anyways, thanks for all your hard work Randy! I noticed that you mentioned you will upload version 1.6 but I can't seem to find a link. Is it live?
By the way, I wasn't happy with the performance of 1.4 so I went back to 1.3 which didn't change the performance by much. I did notice that it seemed to run perfectly after the flash until I started restoring my apps. Mind you, I don't have that much installed and all my videos/pictures etc. are on my external MicroSD. I think I had used around 5GB but decided to erase some. I now use around 3.5GB and can notice it being much smoother. The areas in which I can feel a difference are in the speed that apps launch, on screen keyboard response, input registration speed in the browser and general interface response. I never had a problem with games performance or watching HD movies.
I'm not sure if this is related but I read that JB 4.3 is supposed to help the Nexus devices improve performance by fixing a problem with the way Android handles storage or something (it went right over my head). Reports only seem to mention that it's supposed to help the Nexus devices since they said the problem only existed with them (I could've misunderstood), but perhaps it's an overall Android problem?
That new thread is sticky'd to the Pipo forum.
Randy
Originally posted by freaksa View PostHi guys,
Just to let you know that you can install CWM flashable zips via CWM recovery. I've installed Crossbreeder through CWM. Backup works too, though have'nt tried restore.
There are currently 2763 users online. 1 members and 2762 guests.
