Firmware Android 7.1.2 Stock AlfaWise H96 MAX (Rk3399) 4Gb/32Gb
They have just sent the firmware to me and đid not give any chảnge log, trebor. We are now as their tester 😂. I have not tested on my 4k tv yet. Still crashed when using nova launcher and others launcher. Black screen on first boot, need to unplug and replug and the box work fine. Trebor, for the weird stuff that you said, what is it??
If you have follow correctly the instructions driver instalation etc. you shoudnt have any issues probaply smethong went wrong i have the h96 max 2/16 and no issues installing this firmware http://freaktab.com/forum/tv-player-...2gb#post660920
which is the previous one havent tried the new one yet.
Hi to both ,
please use for flashing a RK Device Batchtool 1.7 & 1.8 or AndroidTool 2.35 or 2.39 .
Hope you got Drivers installed , plesase use as possible Driverassistant 4.5 , u can
get it from here :
https://m.mediafire.com/folder/2x89d...Rockchip_Tools
Batchtool u can download over search in big G , good luck / please report / gefatternLast edited by gefattern; 07 September 2017, 16:00.
Originally posted by teters01 View PostAfter it says success on factory tool 1.42 i just unplug it. And then it wont turn on. Doesn't even have a power led and no h96 max logo. Just a black screen. Any fix to make it work again. Thanks in advance
Which option in factory tool did you choose restore or upgrade? The correct option is restore.
Did you plug right power adapter (5V and 2.5A) that come with the box? Try to connect the box to your pc again by using factory tools or batchtool to see if the box can connect to pc and try to re-flash (Use toothpick method in the av port - must plug in power adapter before connect usb to pc).
There are currently 1680 users online. 3 members and 1677 guests.
