Model: A5X Max Type: TV Box System: Android 7.1 Processor: RK3328 CPU: ARM Cortex-A53 Core: Quad Core GPU: Mali-450 RAM: 4G RAM RAM Type: DDR3 ROM: 32G ROM Max. Extended Capacity: 128G |
Decoder Format: H.263,H.264,H.265,HD MPEG4 Video format: 4K,MPEG1,MPEG2,MPEG4,VC-1,VP6,VP8,VP9 Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,WAV,WMA Photo Format: BMP,GIF,JPEG,PNG,TIFF Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes Bluetooth: Bluetooth4.0 Power Supply: Charge Adapter Interface: AV,DC Power Port,HDMI,LAN,SPDIF Language: English,French,Germany,Italian,Japanese,Multi-language DVD Support: No HDMI Version: 2.0 Other Functions: 3D Games,3D Video,DLNA,Miracast External Subtitle Supported: No HDMI Function: HDCP RJ45 Port Speed: 1000M |
System Bit: 64Bit WiFi Chip: 8723BS |
Power Type: External Power Adapter Mode |
Product weight: 0.2000 kg Package weight: 0.4700 kg Product size (L x W x H): 11.20 x 11.20 x 2.20 cm / 4.41 x 4.41 x 0.87 inches Package size (L x W x H): 20.80 x 13.90 x 6.50 cm / 8.19 x 5.47 x 2.56 inches |
Package Contents: 1 x TV Box, 1 x HDMI Cable, 1 x Remote Control, 1 x Power Supply, 1 x English User Manual |
A5X Max + RK3328 TV Box Android 7 4/32GB Dual WiFI Gig Lan BT4
GearbestLast edited by trebor; 24 November 2017, 00:03.Tags: None
Today thanks to Gearbest we can have a close look at the
Specs are looking OK,
Let's see what it's made of.
The Box
What's in the Box
Ports.
Some Venting
Remove the base
Up close and 2 WiFi Anttenae
Top Side
Up close
Gearbest
To Continue..
Startup Very Good WiFi and Ethernet Good
Google also good with no problems noted with Login, Playstore, Apps etc.
No upper or lower bars
Has Root, Dont update SU Binary or you will have boot loop
UI we have seen before and used before
Lets have a look
The Wizard
UI, Apps and System Information
DRM Info
Ram and Storage Truth
CPU-Z
GeekBench CPU > http://browser.geekbench.com/v4/cpu/4982105
Geekbench Compute
AIDA64
A1-SD Bench
YT 1080 looks OK
Unit Does most pretty good so far, all happened pretty easy and no weird stuff as yet...
A day on the bench and does pretty....
Forget to mention the Clock, not to bright does the Job and cats like its also..
Again thanks GearbestLast edited by trebor; 25 November 2017, 06:17.
Hi. I've recently just gotten this box (from geekbuying) but somehow it's plain without root and any installation of kodi etc.I cant seem to root it nor install supersu (playstore will have error 504). I noticed from other online forum that there is a firmware for A5X Max, not sure if this firmware is applicable to this box (cant see the difference between the 2 boxes besides the + sign on this box). Would you be able to let me know how to get the right firmware (and if its pre-rooted) for this box or guide me to the right tools to root my box and/or fix playstore supersu installation?
thanks.
A5X MAX+ KODI 18.0 ANDROID 7.1.1 RK3328 4GB/32GB TV BOX FIRMWARE UPDATE 20171220
AS Found
Glad to share the firmware for A5X MAX+ TV Box
PC Flash Firmware
Source: blog.geekbuying
I've managed to flash this and fixed the root issue, but this version still doesn't come with the navigation panel nor the notification panel. anyone managed to get those 2 things sorted or recommendations of apk to install it into this box? also it seems that I am not able to install live wallpaper to this, while the apk installation works fine, when on the preview of the live wallpaper, the buttons for options and apply wallpaper are missing, anyone have any idea to solve this?
thanks.
Kush, the ROM trebor pointed out is rooted. Just flash it. It does not have SuperSU included, or any other app to control root access, but it is rooted, I checked.
Unfortunately, flashing requires this strange Standard_A_USB_male to Standard_A_USB_male cable (like the one below). You can buy it or you can cut two regular cables in half and solder together two pieces of cables (connect wires of the same color) to have two A male connectors.
Use USB-4 socket on the A5X to flash, others will not work.
BTW, if anybody found (or created) an UI app with a navigation bar, and/or notifications for the A5X, please post it here :-)Last edited by JerzyD; 23 February 2018, 17:05.
There are currently 3282 users online. 0 members and 3282 guests.
