Thank you.
A5X Max + RK3328 TV Box Android 7 4/32GB Dual WiFI Gig Lan BT4
Originally posted by protackle View Post
Hi Wassco, any chance you can send me a PM with the link for 7.1.2. pre-rooted? I have looked everywhere and can't find it. The ones I founf the WiFi, LAN and BT don't work.
Thank you.
If the Pie firmware on A5X Max doesn't exist, they must use very early alpha Pie builds full of bugs.
How it's bricked that I don't know, it's from my friend.
When I connect it to tv there is no signal and just red light.
Tried to press reset button and apply power (adapter is ok) but nothing, no recovery.
Then I tried to connect to PC with A-A usb cable and flash firmware with RK tool.
I installed drivers with DriverAssitant_v4.5 but PC don't recognize box when I connect it (use usb no 4).
Pc not recognize it at all, no connection sound and no device in Device manager, tried with all 4 usb ports in laptop.
Found online that must put device in Mask mode to flash rom with shorting pins.
Tried with pins that I marked on picture but nothing, no connection to PC.
Want to ask if anybody know what pins to short to put box in mask rom mode and flash firmware with PC.
Originally posted by Nebojsa View PostHow it's bricked that I don't know, it's from my friend.
I think that is not the problem.
When you connect new device to PC there is connecting sound and you will see "unknown device" in device manager.
That device will not work until driver is installed but surely will be visible.
In my case there is no connection sound and no device in device manager, like I didn't plug it at ali (wrong pins or something).
I try also with Windows 7 on desktop PC but it's the same, no connection at all.
go short pins, keep shorted, insert usb male to male cable to the OTG usb port and try if that helps
There are currently 1932 users online. 2 members and 1930 guests.
