Tanix TX92 Amlogic S912 CPU Android 7.1 OS 2.4G / 5G WiFi 1000M LAN BT4.1
Originally posted by cluber77I just noticed that when my tv box becomes hot the internet connection is very poor even with LAN connection, I always need to restart the box to solve it, any one has this problem also?
Personally I didn't notice something like this even at 80 degrees.
Unleashed by ONEPLUS 3T rooted
I made a small modification to my tanix.
I have a router very far, through 3 walls one of which is very thick. In the shopping equipment, the speed of the wifi was at most 0.5 Mbps. In general, almost without the internet. After modification with this standard antenna is about 2.5 Mbps.
I tried to make a homemade antenna from two squares (look in youtube) - the speed was up to 12.5 Mbps. In my conditions, I think it's normal.
The homemade antenna has not been completed yet, but even on such as in the photo is already relatively good. I'll finish the homemade later and use it.
This is default antenna =)
Originally posted by cluber77Hi, I'm asking about root on this tv box, I have rooted the tv box but I cant find SU, also I installed youtube ad blocker but I'm still getting ads' , how can I fix it?
Regarding the YouTube ads , I know that you can block them through Xposed.
Regarding the Wi-Fi on the Tanix tx92 ...
By default, it is very weak. I'm sure that on other tv boxes without external antennas everything is exactly the same because instead of antennas they use a small sticker with tracks. Such a thing will work well only close to the router.
With the help of homemade antenna like in the photo (you can find on youtube how to do this), I got these results through 3 walls.
So if you have a weak wifi, you can do something like that. Can be useful for someone.
Originally posted by cluber77 View PostCan we install fan to this tv box? Maybe it will help?
Less number of enlarged holes in the other side .
Placed a small USB blower there.
No heating problems.
Not even if I take the fan out. The vent holes help a lot.
Those small vent holes really restrict heat dissipation .
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by panchovillaEnlarge the vent holes. I used the smallest center drill . The picture makes it look bad but it looks ok in person.
But the blower sounds like a bad idea because of the noise.
Originally posted by RASTAVIPER View PostFirst of the device comes prerooted. What do you mean that you have rooted it?
If I'm installing supersu i can't see nothing there, I'm not seeing the supersu grant permission popup when I need to get it.also, I installed the Xposed with the youtube ad blocker. Addon but I'm still getting ads'
There are currently 4208 users online. 1 members and 4207 guests.
