Tanix TX92 Amlogic S912 CPU Android 7.1 OS 2.4G / 5G WiFi 1000M LAN BT4.1
    Ok, I received today this tv box, everything works fine, is there a way to block the ads' in youtube application?
    And btw, is there any way to check if I really have DDR4 RAM?
      Originally posted by cluber77
      Can you give a link to download this version for tanix tx92 please?
      If you are talking about the Xposed, I gave the link a few posts earlier.
      And there is no specific link for Tanix. The installation file is universal.
      Unleashed by ONEPLUS 3T rooted
        Just received it also!
        9 days to my door!
        It's for sure strange the Tanix UI and for start I have troubles with my airmouse, as it doesnt work correctly with this box. It fails to cover the whole screen.
        Also, the spdif cable that I had for my speakers is not compatible with this box, although it was fine for my previous box. I need to check what kind of cable does this need. Anyone knows what is this type exactly?
        Something else is that exit from the Tv Center takes around 8 seconds,which for sure it's a lot for a new device with very few apps installed.
          Guys is this the SPDIF cable that is compatible?
            For those who have received it recently, does it come with a remote and hdmi cable?
              Yes.
              Both are included.
                Originally posted by RASTAVIPER View Post
                Yes.
                Both are included.
                Thank you for your quick response. I wonder why Gearbest says Package Contents: 1 x TV Box, 1 x Power Adapter
                  sorry for offtopic
                  guys you can get Vorke Z6 today for 57.99$ on geekbuying with coupon code PAYPAL just letting you know
                    Originally posted by JoseM View Post
                    sorry for offtopic
                    guys you can get Vorke Z6 today for 57.99$ with coupon code just letting you know
                    what is the coupon code?
                      PAYPAL
                        PAYPAL
                        Thank you. It works on Geekbuying. I think the benchmarks for the Tanix TX92 and Vorke Z6 are similar. Not sure if one has the edge over the other. Another member, 45Wheelgun, said the TX92 doesn’t run 64-bit apps and games, only 32-bit, i.e. Kodi. That’s a downside to the Tanix. Maybe someone can clarify if the Vorke has the same drawback.
                          Do you have anymore info regarding the Tanix and only running 32 bit, or a link to the thread? I'm trying to decide between the TX92 and Z6 and that might help. Thanks.
                            Originally posted by trebor View Post
                            All run 32 bit A7 at this stage looking at Antutu info also the TX9 plus.
                            Thanks. Any preference between the two? I’m not seeing much if any difference.
                              Much the same, whatever you go with be happy with.
                              A few deals about I think still if your ruled by the $
