Pipo M6 4.2.2 RileyROM 1.6 [SDK 2.0] - [Feedback]
Re: Pipo M6 4.2.2 RileyROM 1.6 [SDK 2.0] - [Feedback]
@ rrileypm ; Could you unpack the official rom (if you have it) and confirm/debunk this?
If this is true, I don't see any other real reason, than a conflict with the M6 hardware and the sdk. To my knowledge, the development kit itself hasn't "leaked" yet. If it had, Rockchip roms would likely be in quite a different place by now.Support your local flasher
Current devices : Pipo MAX M8 Pro - Samsung Galaxy S4 - Intel NUC
Originally posted by pr0xZen View Post@ rrileypm ; Could you unpack the official rom (if you have it) and confirm/debunk this?
Originally posted by gur View PostThis last 1.6 firmware is definitely NOT SDK 2.0 as its not as responsive as 1.4 and 1.5.. I think this should be named 1.5b or should be stated as SDK 1. Anyway let's hope a better official sdk 2.0 comes out asap! I think I will go back to 1.5...
I do have a template I can provide to make a flashable zip file, but I've never tried it. If you want to play...download one of 900supersport's Cube U30GT2 ROMs. In it is a folder called CWM template. There is a readme file that explains how to set it up.
One limitation is that you can't change anything in the parameters. For instance, if you have 4gb user app space installed on your system, you can only flash that same setting through CWM.
Try it and please let me know how it works for you. I can't really support it, because I haven't used it...but 900Supersport can answer any questions you might have.
Enjoy!!!
RandyRandy
Originally posted by freaksa View PostDefinitely the same kernel. I have unpacked it and compared kernels; the one on this is the same with 1.5.
Originally posted by gur View PostHave you upgrade the firmware on your device? Do it and you will understand what I mean.. Unreal Citadel is % 1.5 slower on my machine and overall browser and settings menu are laggier. It is so noticable because so far I tried 4 firmwares.. This one is a bit better than stock but laggier than 1.4 and 1.5.
Originally posted by frbelive85207No, I have'nt. I do not see any reason to do another flash since kernels are the same. I'll stick to 1.5 for now, maybe come 1.7.
Originally posted by Mobius7 View PostCan you add loading module tun.ko for OpenVPN to boot.img?
So far, you are the only one who has tested it.Randy
Originally posted by gur View PostThanks pulsar! Has snyone tried 1.5 and 1.6 together and compare the lagginess? So far 1.5 was best but ifwe return to sdk 1.0 ı am afraid it would be more laggy..
Sent from my M6 using Tapatalk 4
There are currently 6558 users online. 5 members and 6553 guests.
