It's probably the same in this modified stock firmware.
[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Sorry, maybe this topic has been covered in one of these posts.
i have been using this Mecool (LB version) for a few months and I absolutely hates this Andriod-TV. The Leanback home screen is restrictive and a lot of apps cannot be installed.
Is there any way I can convert the box back to regular Andriod?
Originally posted by Mis3 View PostSorry, maybe this topic has been covered in one of these posts.
Envoy? de mon XT1562 en utilisant Tapatalk
Sorry for my badly english
Maybe I am not familiar with Andriod TV, I found it very restrictive and hard to use.
Is there any way to install regular Andriod to it?Last edited by Mis3; 02 December 2018, 21:39.
#1132.1Guest commented03 December 2018, 12:35Editing a commentCheck out the Stock and Nano variants: http://freaktab.com/forum/tv-player-...android-tv-7-1
Originally posted by fgetkate View PostDoes anyone have any advice on getting Show Box to run? I just installed the app from Aptoide TV and now I get an internet connection error when I launch the app.
Thanks in advance.
Originally posted by sweetnonso View Post
Show box has been officially taken down, it no no longer works. You could try downloading 'Cyberflix', its an alternative, a very good alternative.
Hi!
I've just flashed my box to your ROM and now I'm having issues with Netflix.
Tried all the solutions I've found: BurnKey Tools, the tablet app and so on, but now I'm getting a pop up window that say that could not reach Netflix network.
Do you have some clue on whats going on?
Ps: Is there a link to download the default sotck ROM that comes with it originally?
Thanks in advance.
Thanks in advance.
You can download a build version off the Netflix site which will allow you to watch Netflix. I had Netflix going great but it crapped out in the last few days and won't work anymore. The version I'm currently using is off the Netflix site but it's not the Android TV version it's the mobile version. It works just fine but you need an air mouse to operate it.
Hi Mate
Do you mean that Netflix app for older Android devices or some beta version released recently? I googling it but I'm a bit lost.
Thanks for the reply.
Start at the bottom and work you way up to you find what works for tou. I'm using 5.1.0 build 17074
Yes it's an older version of Netflix. They have a beta version on their site you can download but I got mine from here...... http://Netflix.en.uptodown.com/Android/old
There are currently 2140 users online. 1 members and 2139 guests.
