I had the same issue on my box (LB box with BT voice remote ) : the last update 20180803.173707.V0213 failed with status 7 error message. I'm not a geek or (Code Man)
.gif)
Fortunately , After many test , I Succed and my box is Updated Now .I share my solution .Hope it can help you and works .
Please let me know and others members if it works for you!!
1- Step 1:
Download ROM 20180316.143701.V0213 here : http://freaktab.org/a28c3f52268572bb . This is the stock rom for LB boxes with BT voice remote, ATV version .
And Flash the ROM With Amlogic USB Burning
2- Step 2 :
Download OTA 20180417.150752.V0213 here : https://mega.nz/#F!YNw1HarI!6KT6bK34cEzxte0htOmFdA .
Copy the Zip File to a Blanck USB device.
Insert the USB device in the box
Do a "Local Update"
If done right, you should see your Zip file. So click and go ahead.
3- Step 3 :
If done right (Step 1 & 2) , your box is Properly updated .
You have just to perform the update OTA 20180803.173707.V0213
4- Step 4
That's it
Enjoy
