[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by isma45 View Post
Ahem...First of all, sorry for my english, anyway... I tried this tv box with several TVs in my house (Samsung, LG and so on) and each remote control works well. Unfortunately, on the big 4K off-brand TV in my living room (where I use m8s box), when I press the "OK" button over an Android icon APP in the home screen, I see only a trash bin (with apps uninstaller) and in that remote control there isn't any button associated to the default "OK" push button. So, for "OK" button now I'm using mouse, airmouse or gamepad but...if I wanted to use the default remote control of my television, please, where is the right path of the IR configuration file and how can I change the key function of that "Uninstall" button to the "Ok" button?
Originally posted by TiagoDM View PostGuys, any solution - not involving mechanical fans - to overheat issue? My box turns off because the soc heats to 85ºc+... any easy way to underclock a little?
Hello, It says in the begining description- This firmware is designed for earlier models of the M8S Pro L with the QCA9377 wireless chipset. If you install it on later (non-LQ) hardware, WiFi and Bluetooth won't work.
#1104.1Guest commented12 November 2018, 11:56Editing a commentIf the number on the bottom above the bar code ends with "LB", then you have the Broadcom BCM4335 wireless chipset.Last edited by Guest; 12 November 2018, 12:24.
Guest
Okay, I've created a new thread for the LB variant (BCM4335 wireless chipset) of this custom ROM here. Many thanks to Ewald Bayer for donating the hardware!
Changelog (20181111):- Updated to latest M8S Pro LB OEM firmware (20180803.173707.V0213)
- Latest build from Open GApps (20181111)
- Google Cast service works from Chrome browser, but apparently requires Google license to work from Android apps.
- TVStock Variant: BURN PACKAGE (1.00GB IMG file), OTA UPDATE (552MB ZIP file)
- Flash burn package with Amlogic USB Burning Tool v2.0.8 or BootcardMaker v2.0.0.2
Originally posted by Magendanz View PostOkay, I've created a new thread for the LB variant (BCM4335 wireless chipset) of this custom ROM here. Many thanks to Ewald Bayer for donating the hardware!
Magendanz hi .
I really apreciate your work and i really thank you but i have a problem .I have wiped ''accidentally'' this tv box and i need a rom to get it back alive .I was reading your posts and i am having the same problem like Mples but your efforts stopped at page 4 ,when you are saying to him that you are going to send him a p.m. with a modified rom
Mples :
10-20-2017, 12:16 It's failing to mount the existing system partition. Did you wipe it?
yes I wipe it my friend
- Magendanz commented
10-20-2017, 12:40
Well, that explains it. It's hard to check the build properties on a partition that's been wiped. I'll need to make a special .zip file just for you that removes all environment checks, so let's move this discussion to private message.
You will tottally save me if you send me this p.m. with the rom .I have a workable twrp but i cannot install anything !!!!! I am in the same situation ...:-(
This was before i messed up with the wipes :
There are currently 2212 users online. 0 members and 2212 guests.
