is there a way to keep the android tv version but change the launcher?
[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
I have my M8S Pro L on the stock ROM/firmware. Am I understanding this correctly that all I have to do in order to install this Nexus ROM is download the OTA update https://1drv.ms/u/s!AoqocX31ecnXgatjUTLoMCBz7XqfEQ and then go in the OTA update section of my box and click local and wipe data and point it to the zip file and let it do its thing?
Originally posted by klouny View PostI have my M8S Pro L on the stock ROM/firmware. Am I understanding this correctly that all I have to do in order to install this Nexus ROM is download the OTA update https://1drv.ms/u/s!AoqocX31ecnXgatjUTLoMCBz7XqfEQ and then go in the OTA update section of my box and click local and wipe data and point it to the zip file and let it do its thing?
Originally posted by sweetnonso View Post
Basically yes.
Hello,
i have used this rom for my M8S Pro L, but i have a problem with Netflix now. Everytime i start it i get the error message "ui-800-3" which i tried to fix, but everything i found didnt work. Is this a common problem with this build or is there a fix for that?
No way OTA by "local update option from Settings->About->System update" because the firmware Changelog (20171115) don't have this option, it's only in next firmware Changelog (20171202)... And this box have no reset button so the only solution is
1. Enable Developer Mode
2. Enable terminal
3. Go to App Drawer
4. Select Terminal
5. Tap reboot twrp
and select your zipfile or reflash your device !
Actually, you need to type "reboot recovery" in the terminal window, but for a long time that was the only way to do OTA updates from these custom ROMs.
Remember, you can also update with Amlogic's USB Burning Tool or Bootcard Maker using the burn package. From the terminal window, just type "reboot update" instead.
Guest I used this documentation for windows: https://www.cnx-software.com/2016/11...ogic-tv-boxes/
Is there a way to get those keys back?
Hi, I wanted to install SuperSU and got "su binaries occupied" message, so I've read some googled solutions and downloaded previous version of SuperSU. This time I've got "succeded" message but after pressing "reboot button" I'm stuck on the "spinning wheels" (device reboots, displays NEXUS logo then the "spinning wheels"; I've waited 20minutes in that state but nothing happens ). Can someone confirm, that using superSU is safe on this ROM and something just went wrong or there is no way to safely install superSU? Next question is, of course, what do I do now? Does pressing menu button on the remote work on this ROM just as on the OEM version or do I have to short reset pins? What do I flash after booting? Update.zip or img? Sorry for my poor english and for asking lame questions
Guest Is there any way to write on the sd card? I have tried to put it as internal storage from settings - storage but corrupts the sd card. And by formatting ntfs or exfat, I can not write to it from a kodi video plugin (quasar), to download the videos on the sd card.
Guest The problem is that fat32 has file limitation to 4gb. If kodi is used to watch a fullHD HD or 4K torrent, it will occupy more than 4GB and it will not be possible to view it.
I have found several ways to fix it, but I have not tried it yet. One of them is to modify the platform.xml file and add these lines. <permission name = "android.permission.WRITE_EXTERNAL_STORAGE">
<group gid = "sdcard_r" />
<group gid = "sdcard_rw" />
<group gid = "media_rw" />
</ permission>Last edited by Albertron; 17 February 2018, 22:25.
Originally posted by Albertron View PostGuest The problem is that fat32 has file limitation to 4gb. If kodi is used to watch a fullHD HD or 4K torrent, it will occupy more than 4GB and it will not be possible to view it.
</ permission>
I just tried to modify that file and it works !! I can now download torrents on the sd cardMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
What app did you use to modify the platform.xml file, and where is that file located?? Thanks
Guest The latest version of VLC player(version 3.0) now supports google/chromecast to all android device including this device. I was wondering if there's a way to reverse that same engineering to make this device receive cast from every other platform?
There are currently 3420 users online. 0 members and 3420 guests.
