[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
    Maybe you have some sort of hardware failure
      Originally posted by nitro82 View Post
      Here is the Videostrong reply to my email:
      Hi Michele,
      Glad to hear from you.
      1. It doesn't support Chromecast right now.
      2. Sleep state, it resets because of low-power design.
      3. About it freezes, we have tested and the heat isn't the reason. Please try to restore the factory default settings. And upgrade the firmware as follow:
      Regards
      Cyrus
      I will try the new update (hoping it resolves freeze issues) and will look forward forGuest version.
      Hello Nitro
      Just registered to ask on the length of time for Cyrus to reply to your original email? Been waiting over a week and no reply. Maybe you could pm me a direct email if possible?
      ​​​​​​Thanks.
        Originally posted by Mrfoxx1 View Post
        Hello Nitro
        ​​​​​​Thanks.
        He replied to me in the same day. I sent mail to the address shown on their website: [email protected].
          Hi Magendanz,
          Nick Stekovic on YoTube says everyone is getting freezes and I am the only one who isn't ? Am I really that lucky ??
          Add a public comment..
          Nick Stekovic 2 hours ago
          Why are you promoting the ROM that has freezes and is not ready to be used?
          Petrev X 2 hours ago
          Strange ? Neither FW freezes for me or anybody else I know of !! Many happy users. Great box, great OEM FW, great upgrade FW by Magendanz.
          Worried ? Don't install it. Unconvinced ? Don't buy it.
          Pro L Box can have overheating issues - Many solutions in videos and on Freaktab.com
          Pro + box if you don't want/need Bluetooth
          Nick Stekovic 1 hour ago (edited)
          I have been working with Magendanz and directly with the factory, not sure how that is possible that you have no freezes when all of us do. If it's working so well what is the firmware date, if your temperature is above 55C not a good sign that your CPU is going to last.
            Hi Magendanz,
            I have experienced SOME freezes, but not very often, and I leave my box running 24/7. I am running it as it came from the factory, but with a ton of side loaded apps. It does run quite hot, but have not seen any negative effects from the excessive heat. On the rare occasions, that it did freeze, I could not determine what caused it.
            I have another Pro (non "L") that is running LibreELEC. It has been running months non stop as my tvheadend and Emby servers. It just sits on my network as my DVR backend, and just runs.
            Overall, this Mecool M8S pro and "L" boxes are my best go to boxes, and I have many.
              Good power packs also a must, especially if leaving on 24/7,
              Using power strips also can cause issues with loose fittings, cheap is not good.
              Only many boxes ?
              You saying there is more room before you have too many
              Good to see
                Hi Magendanz,
                PX what's the purpose of posting my postings on this forum?! I was the one that got the latest few Firmwares directly from factory so please erase your comments there is no point to it. As I said before when you have thoroughly tested the box and learned why there are flaws then you will understand.
                  Are you running CPU-Z overlay to monitor the temperature? What are the temperature readings on average? I am at least at 70C in idle when watching a 1080p movie with heavier compression it gets to 80C easily.
                  I am getting easily 2 freezes a day and I don't shut my box either. Also not sure how you are turning ON/OFF your boxes but CEC HDMI is also not working fyi P.X that is also not working in case you haven't even tested it. So likely if you turn your box on and TV oFF in the morning when you turn the TV ON there is nothing nada on the screen.
                    Hello Nitro
                    ​​​​​​Thanks.
                    These are their generic responses ... Cyrus claims he never ever got a freeze which is impossible considering that most of us running into at least one.
                      Originally posted by IMDB View Post
                      Hello. I have a TB BOX M8S Pro L 3gb ram 32GB rom. I installed the OTA stock rom and everithing works fine for 2 days. Now, the TV BOX is with the blue led always on and it hasnt got image. I readed the post and I saw that it was briked. I try all the solutions posted and dont works! There are a new solution or it will be a new solution in the future or is totally useless vor ever? Thank you!!
                      You have to open the box and short it in order to get to recovery, it should be able to get there if not then likely your eMMC is fried or something on the chipset (Chinese ISO9001 my ass pardon my french).
                        Only many boxes ?
                        Good to see
                        You should feel guilty about goading me into purchasing all these boxes and not having any $$$$ left to pay my rent.
                          I always run CPUTemp app overlay, and my temps are similar to yours. I don't use CEC (no idea how to use it), but I have my box connected a $5 USD SonOff WiFi enabled smart switch, I just tell Google to turn my box on/off.
                          Have you tried to see what is causing your lockups?? I would do a factory reset, and monitor each app you install. I would run your box for a couple of days after a reset without adding any apps and see if it still locks up. Also, check any variables, like cables or peripherals, and maybe run the app SysLog (side load).
                            And in the logfiles what should be off?
                              I'm running into quite a few random reboots since updating to the latest build. Is there confirmation that there is a flaw with this build? Can't see any mention of issues on Magendanz post of the new release. Is it worth downgrading? I know the issue is not heat related. At first in thought it was Netflix app but it's doing it with other apps during streaming.
                                Guest Good evening to all, which file must be used to update, the link of the Changelog called fixed.zip 20180205 or that of the ota update 20180310? Thank's for your job
