[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Hello!! Sorry for my english. Just a question: where i can find the original firmware if i would like restore it? this is the original firmware M8S_PRO_L-ota-20180205.11165 2.V0928-fixed.zip?
thanks in advance
I just updated my device and somethings broken with YouTube. On previous versions when I watched 4K 60fps videos - after about a minute the image got frozen but the audio worked fine. With the newest version all videos - 1080, 1440, 2140 etc. got this issue. YouTube is basically unusable right now. Is anyone aware of this issue? Is there any solution being worked on or the only way is the revert back to previous version?
Thanks!
Originally posted by newkind View PostI just updated my device and somethings broken with YouTube. On previous versions when I watched 4K 60fps videos - after about a minute the image got frozen but the audio worked fine. With the newest version all videos - 1080, 1440, 2140 etc. got this issue. YouTube is basically unusable right now. Is anyone aware of this issue? Is there any solution being worked on or the only way is the revert back to previous version?
Thanks!
Originally posted by Flo90 View Post
Clear cache, uninstall all update of youtube. Reboot system, test. If ok, update youtube and test again.
Hello,
I just got a M8S Pro L, without voice remote, and flashed this ROM.
I really liked it, but I’m having some strange behavior.
When I press “left” key on the IR remote, TV screen flash like HDMI cable was removed and then comes back. The “left” command is understood by the M8S, but I got this flash every time I press it.
The same doesn’t occur with my keyboard that uses radio, or using the TV remote (CEC). It only happens with the IR remote. I tried a remote from another TV box that I have and the same happens.
I don’t remember if the same happened with factory firmware.
Does anyone have the same problem? Any solution?
thanks.
thanks.
Hi guys, I am going to buy this box for androdi tv and voice ocntrol, do you think it will be the best box for android tv and vocie control for 60 euro? or maybe some other variants? Will Mecool M8S PRO L lag? It's the main question beause I am buying this for parents who don't know IT stuff.
thanks.
There are currently 2153 users online. 1 members and 2152 guests.
