[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by repulse37 View Post
Right on the link, tried to upload here but doesn't seems to workMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Yes, the link is working now. I don't see anything out of the ordinary. A 480p, H.264 video codec in a MKV container. One thing I noticed is the Ogg audio codec, and I am not familiar with that codec. You may want to do some research on the Kodi forum about that audio codec.
Originally posted by Loex View PostWhat about LS model? My stock firmware is M8S PRO L-userdebug 7.1.1 NHG47L 20180205.111652.V0928. Can i install TVStock Nexus ROM?
As you have a box with V09xx FW as std. you should be OK to install a Custom FW based on the same generation revision.
Newer boxes with V02xx FW as std. should wait for a new version of the custom FW for these changed HW boxes.
Hopefully Magendanz can get past the issues that Videostrong have introduced ...
Keeping fingers crossed here.
Hi - Don't know if you got an answer on this ?
Guest
The problem has to be in the hardware chain and the HDMI cable is the most obvious. I have a 4 port HDMI cable between my AVR and Mecool box, and it passes through my HD audio without issues.
Guest
Originally posted by supermal View Post
Agreed.hdmi cable is likely suspect.sometimes it's hdmi ports themselves.best to try all options.mecool to avr /avr to tv best route when using hdmi audio passthrough.
Originally posted by mynameismartha View Post
Mecool to avr /avr to tv is my current setup, it avoids any further complications with ARC. Just tested with brand new HDMI 2.0 cable and still getting the same results so it doesn't appear to be the fault of the cable. Any other ideas?Last edited by supermal; 07 May 2018, 21:12.
Guest
try kodi 17.6 again with new cable.kodi 17 was built from the ground up to support all hd audio formats.i have tried my test files using mx player and it does not support true-hd.only got dts with it on dts-hd ma file.so other players have limited support.stick with kodi 17.6 until you get success to simplify things.you need to get true-hd and dts-hd showing in kodi set up.sorry i dont know why they dont show.i have tried changing my kodi settings to see if i can get same outcome as you to narrow down the problem but i still get all audio options showing.all i can think to try if you still have no luck is do a factory reset in case a glitch has occured when firmware installed.is it the only android box you have?you could try putting kodi on another box to see if settings are same?the kodi build i am using is 17.6 git:20171114-a9a7a20 nov 14.2017 to narrow down further.
Tried Kodi 17.6 again, still no DTS-HD or TRUE-HD options in the audio settings. Factory reset may be the last possible option it seems. Out of interest what is the current firmware on the L box you've been testing on? I'm currently on Kernel Version 3.14.29 and Build Version M8S PRO L-userdebug 7.1.2 NHG47L 20180417.150752.V0213
Guest
I'm on the same.did you check kodi version is same as mine?
Guest
PS in case anyone can shed any further light, here is the Kodi log when attempting to play a TrueHD and DTS-HD sample file - https://paste.kodi.tv/emurogazud
No update found on OTA. Is it possible to update to latest M8S Pro L OEM firmware (20180205.111652.V0928) ? Currently on (stock) 7.1.1 NHG47L 20171117.164057.V0928
Also, i saw here some issue with wifi, it it ok now, or i'm totally wrong and it's unrelated ?
So a factory reset later and everything is still pretty much the same. No dice with HD passthrough on several versions of Kodi and SPMC. Time to contact Gearbest, looks like I've been sent a dud!
PS in case anyone can shed any further light, here is the Kodi log when attempting to play a TrueHD and DTS-HD sample file - https://paste.kodi.tv/emurogazudLast edited by supermal; 08 May 2018, 16:34.
There are currently 4600 users online. 0 members and 4600 guests.
