Wondering if there's something I'm missing? My Kodi settings on expert mode don't have TrueHD and DTS-HD reciever settings as seen here - http://50.28.19.13/~vidabox/kb/admin...reaming_12.jpg
[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Guest
Originally posted by Magendanz View PostOkay, I've run into a problem using the 20180417.150752.V0213 OEM kernel. Going through my normal development process, I was able to build all variants with the new OEM firmware. However, they switched from the QCA9377 to the BCM4335 wireless chipset, so WiFi and Bluetooth don't work on any of my M8S PRO L boxes.
My strategy was to just pull over the latest QCA9377 kernel and init.amlogic.wifi.rc, repacking the build image using the usual procedure. However, this results in a hang after the logo screen. No matter what I did, the old kernel would always fail to load, and the new kernel is missing the kernel compatibility layer that the QCA9377 uses through compat.ko.
Does anyone have a newer OEM firmware release for the M8S PRO L SKUs that used the old QCA9377 wireless chipset? The latest I can find is 20180205.111652.V0928.
Originally posted by mynameismartha View Post
Unfortunately I'm having no luck with Kodi. I've installed the latest version of Kodi from the play store (17.6) but I'm not getting HD audio passthrough. All DTS-HD MA and DTS-HD HR files passthrough as simple DTS, while TrueHD files are decoded as Multichannel 5.1 and sent through to my receiver.
Wondering if there's something I'm missing? My Kodi settings on expert mode don't have TrueHD and DTS-HD reciever settings as seen here - http://50.28.19.13/~vidabox/kb/admin...reaming_12.jpgMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Guest
Originally posted by supermal View Post
just installed kodi 17.6 from playstore.changed settings in kodi after changing to expert mode.set to allow passthrough and highlighted dts etc.made sure that audio setting on my mecool box was set to hdmi raw.tested using all my hd audio test files and passed 100%.dolby atmos dts-ma dts-x dolby digital.all good!you should get truehd and dts-hd settings when in expert mode.try another hdmi cable and check audio settings on your mecool box.also try deleting kodi and reinstall.you need to get those truehd and dts-hd settings.dont know why they are missing!btw i am using kodi 17.6 version too.
Sorry that's not my device, that's just a random image from google to illustrate the extra settings that I don't see in my Kodi.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Guest
Do a factory reset, there must be something wrong with your installation. All versions of Kodi, SPMC, CoreELEC, etc. have HD audio natively on these Mecool M8S Pro and Pro L boxes, using the stock firmware or modded firmware........
Could you do me a favor and quickly double check DTS-HD MA, DTS-HD HR & DTS:X files from here - https://thedigitaltheater.com/index.php/dts-trailers/ - with MX Player and let me know what your results are. Do you get full DTS-HD passed through to your reciever of just the DTS core like I am getting?
Guest
Using latest stock rom.Magendanz custom ROMs won't work on latest mecool m8pro l boxes because the wi-fi module was changed.
Hmmm... its a new box on the latest stock firmware, arrived from gearbox a few days and ran the latest April OTA update. I've done a few more tests and getting interesting results. VLC is the only player I've tried that is successfully passing DTS-HD variations through. All the others (Kodi, MX Player) only passthrough the DTS core. Strangely MX Player is passing through TrueHD 5.1 successfully but not TrueHD 7.1.
Out of curiosity, since I just installed this version and had not tested Kodi yet, I ran a test. I use the Alpha version of Kodi and tested my Avatar Blueray rip in MKV container and my Denon AVR shows DTS-HD MA.
Are you testing it as a downloaded file or streaming......
Edit: downloaded it from my Windows computer and copied it to a pen drive. Inserted pen drive into my "L" box and tested the file.
Using VLC player, it played in multi-channel
Using MX Player Pro, again, it only played the DTS core
Using Kodi, it play in DTS-HD MA.Last edited by clarkss12; 06 May 2018, 01:01.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I'm still on stock as well, I received one of the new L boxes a few days ago.
Originally posted by supermal View PostIf the Q in LQ stands for Qualcomm and the B in LB stands for Broadcom.what does the S in LS stand for???
Guest
That is what your problem is streaming does not pass through high end audio.you need to test using downloaded hd audio test files.
I'm getting results similar to clarkss12's tests above with the exception being that I'm actually getting DTS-HD passthrough on VLC and none on Kodi. He is seeing the reverse. Have you been able to run the same tests? What results are you seeing?
There are currently 1052 users online. 0 members and 1052 guests.
