[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by weldermike View PostHI, sorry for sounding a idiot but how can it recognise it, when it’s a zip folder and not a image file as I can not see it.
ThanksLast edited by supermal; 12 June 2018, 10:26.
Hi, just tried the image file in the post 675 and it stops and say 98%:[0x30405004]UBOOT/Partition system/Verify partition/Error result. Time 2.45 statistic 1/1
thanks
Edit, all I done was download img and import image while shorting it, using USB burning tool.Last edited by weldermike; 12 June 2018, 14:06.
Originally posted by weldermike View PostHi, just tried the image file in the post 675 and it stops and say 98%:[0x30405004]UBOOT/Partition system/Verify partition/Error result. Time 2.45 statistic 1/1
thanks
Edit, all I done was download img and import image while shorting it, using USB burning tool.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
thanks
If you got to 98%, then your process was correct. Give it a couple more tries, and maybe a different USB port on your computer.
Download img from post 675 and put imagine on to USB burning tool, then I shorted the box using the paper clip while my friend connected the usb to the computer as I already connected the other end to the box.
As it fail last time, when it successfully link between the box and the computer, I put the power lead back in this time and started and all back to when I bought it, WiFi works, DRM level 1 working ??? If I will ever use it and the voice control works too,
to everyone a big big thank you
Originally posted by weldermike View Postit works 100% trust me, now to find out why it went funny in the first place lol
Power on today and 1st time hanged in Colour symbol screen, on and off 2nd time stuck in mecool, on and off 3rd time no picture, before all this it was working like a dream, so maybe I should off updated it after installing the image on post 675.
Have anybody any ideas why it’s crashed again ?
Originally posted by weldermike View PostPower on today and 1st time hanged in Colour symbol screen, on and off 2nd time stuck in mecool, on and off 3rd time no picture, before all this it was working like a dream, so maybe I should off updated it after installing the image on post 675.
Originally posted by supermal View Post
It may be you have a fault on the box in which you should try and get replacement sent out.take some pics of the screen to show them.things you can try are use a different usb connection on your pc.usb 2 is better.try another usb to usb cable.shorter the better.connect power supply to your box as well as usb cable.patience is required these boxes are temperamental!does your box get hot?I use a cooling fan under mine.these boxes have thermal issues.try a different power supply if you have one.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Hi, when I installed the img, I installed plex, retoarch,global player, itv hub, (all apps) I was watching global player (IPTV) for about a hour and turn off and went to work, that it, all its connect to is the TV and WiFi. Tried to reinstall the img over 10 time and gets to 7% (formatting) and times out, have tried force erase all. Was probably looking at buying a fan before it fail again because when it work it worked brilliantly.
There are currently 1373 users online. 0 members and 1373 guests.
