[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by Giannis View Postnatman I 've the same with you Mecool m8s pro L (NO the Bluetooth Voice Version) which came with, M8S_PRO_L-NHG47L-20180316.115110.V0213, firmware. Because I had some issues with wifi I flashed, using android terminal (reboot update) and burn card maker method, at first the M8S_PRO_L-NHG47L-20180316.143701.V0213.img and later the M8S_PRO_L-NHG47L-20180417.150752.V0213.img. Both of them are useless because the mecool freezes all the times or reboot randomly. Although the firmwares are same version (V.0213) with mine Mecool LB version, aren't compatible with the no Bluetooth voice version. DONT FLASH IT. Is there any custom Rom which support the wifi - Bluetooth chipset ? Is there anybody who knoww where could I find (link - source) my first rom img (M8S_PRO_L-NHG47L-20180316.115110.V0213) to recover my box? Thanks a lot.
Thank you very much supermall for your response. My mecool box LB version came with M8S_PRO_L-NHG47L-20180316.115110.V0213 (not atv firmware and with normal remote). After I flashed (using both usb burning tool and burn card maker methods) at first the M8S_PRO_L-NHG47L-20180316.143701.V0213.img and later the M8S_PRO_L-NHG47L-20180417.150752.V0213.img, both of them, have a lot of issues:
a. Freezing many times during boot.
b. Freezing frequently in settings menu, and even in main screen.
c. Frequently BT - WIFI disconnecting (every ten minutes) and reboot required.
I realized, as you mentioned above, the two V0213 atv firmware's, aren't compatible with the no Bluetooth voice version, so is useless to flash them to a lb ver. boxwith normal remote.20180316.115110.V0213, stock firmware or a custom rom which support my WIFI-BT chipset.
The only solution for me, to recover my box, is to find the
Originally posted by Giannis View PostThank you very much supermall for your response. My mecool box LB version came with M8S_PRO_L-NHG47L-20180316.115110.V0213 (not atv firmware and with normal remote). After I flashed (using both usb burning tool and burn card maker methods) at first the M8S_PRO_L-NHG47L-20180316.143701.V0213.img and later the M8S_PRO_L-NHG47L-20180417.150752.V0213.img, both of them, have a lot of issues:
Originally posted by supermal View Post
Looks like it is LB variant but the firmware should be atv with leanback launcher.unless mecool have moved goalposts again without telling their customers!can't put any logic to this at all.i don't think mecool/videostrong even know what they are doing.
Giannis when you loaded the BT remote firmware how come you werent asked to pair remote on boot? How did you go past that? Do share your source once you get it..
Originally posted by Appys View Post
They have made a Frankenstein here in LB variant. How is it possible that with the same board BT/Wifi works on one software meant for the same board and not on the other version..Drivers should be the same right?..I feel LQ/LS owners are the lucky ones... I sent VS an email few days ago they didnt even respond and appears on Aliexpress some Wechip M8S Pro L is also available..this is quickly turning to a joke now...Gearbest has these on sale but I wonder which lucky ones will be buying it right now
Hi Appys. After flashing either 20180316.143701.V0213 or the 20180417.150752.V0213 firmwares, both of them at boot, requested BT remote pairing. Because of I' ve a LB version box with normal remote, I bypass this step pairing the box with my smartphone. The best solution for me now is to flash to an existing custom firmware (losing of course Wifi-BT) and connect to internet via ethernet, hoping in the future to find , my stock firmware (180316.115110.V0213) or a custom firmware which supports my WiFi-BT chipset.
Supermal sendind the box back in China is not an option for now, because it was my mistake to flash my box with the other V0213 firmwares thinking are compatible with my device.
Originally posted by natman View PostI've noticed that geekbuying.com correctly advertise the "voiceless" version as Android 7.1 and the "voice" version as Android TV...
@ Giannis: can you confirm that you also have this unknown KT 63350801 wifi chipset?
Just my crazy thoughts.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
If Mecool and Video strong are indeed monitoring this site, Your new box aka the LB one sucks..you have degraded the components, half times seems the new cheap chip is dead... thrown in a voice remote and retained/increased the price..half of us are outside China and being harassed if we buy off sites like Aliexpress where return costs are inhibitively high and the sellers have us by the throat...its a nightmare buying these things
@ Giannis: can you confirm that you also have this unknown KT 63350801 wifi chipset?Same box multiple chip varieties messed up software
Maybe someone with the new LB version but with the voice remote and the ATV firmware can tell us which wifi chipset its box uses... to further clarify the situation...
In the meantime, nobody can tell me if Amazon Prime Video ever works with the M8S Pro L (any firmware/hardware configuration)?
There are currently 3253 users online. 0 members and 3253 guests.
