You said something bout android TV limitations and Flud being only able to write to its own folder on external drive. Do you mean the internal 32GB drive or the the external HDD. So does that mean I can't just set the default download path in Flud to go straight to the external drive?
About the usb hub to power the drive? My external drive is of the 2TB USB powered drive. My intention was to have the USB fan I ordered with this box permanently connected to one of its USB ports and then the external drive to the other. Having said that I just realized this box only has two USB ports which means I won't be able to plug in my USB wireless keyboard......... ah well I guess I can just plug the USB fan to the back of my PS4pro which is currently next to where the box is supposed to go.
Thanks for the info on the browser, another question is what layout of chrome is the browser going to have? I currently have the layout that pretty much looks like it does on a PC (tabs above the address box) but was wondering if this one will have the layout that more closely resembles chrome on a mobile device (with a numbered tab icon next to the address box that expands when you click on it).
What can you say about the responsiveness...... currently on my 1GB mxq box there is usually like a 3-5 second delay going back to the home screen from nearly any app I am in; albeit this happens randomly but often enough to make me feel like the box is always struggling. And I constantly use the recents menu to esure that I have no more than 3 apps active at any time. Responsiveness is the primary reason I set out to buy an upgrade.
Thanks in advance.
