great!
[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by BPENL View PostNetflix working again with the burn-key http://freaktab.com/forum/tv-player-...se-boxes/page4
great!
great!
Thanks in advance
@Magendanz I broke my My MECOOL M8S PRO L LB variant by installing this rom. WiFi and Bluetooth are not working. So I will like to put two requests:
1.Clearly mention at the top for which variant this rom is like LB, LQ and so on and How to find variant. So any other person doesn't face any problem because of version confusion.
2. It will be a great help if you can help me to get the stock firmware for my version.
Thanking you,
With regards,
Ankur Pathak
Originally posted by ankurpathak View Post@Magendanz I broke my My MECOOL M8S PRO L LB variant by installing this rom. WiFi and Bluetooth are not working. So I will like to put two requests:
Thanking you,
With regards,
Ankur Pathak
Newer 27 November 2017 > Click me (http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s912/mecool/firmware-roms/673617-firmware-stock-otaSorry for my badly english
Thanking you,
With regards,
Ankur Pathak
Originally posted by supermal View Post
There has been several warnings about loading the megandanz custom roms onto the LB variant of you took time to read the posts on this forum before flashing your box.more so if you did so without backing up your stock rom.i hope you have success in recovering your box back to stock .
1. Is nexus tvstock and nano rom availabe for LB variant??
2. How I can enable Google Cast Receiver in my box? I have installed the apk for same from Play Sore. But No option for Google Cast In Settings. Please help. From this Url I came to know it can be done:
https://forum.xda-developers.com/and...eiver-t3491794
And also this option was their Nexus rom I installed and whick broked my device, It can be a great help if you can help us to get it enable by extracting some apk or part from nexus rom.
Thanking you.
With regards,
Ankur Pathak
Yes I have recovered my android box. I would like to thanks Snakx and Freaktab for the orignal firmware for LB Varinat.
Thanking you.
With regards,
Ankur Pathak
Originally posted by Liffeyman View Poston first setup screen, its telling me to hold - and ok while holding the remote near the box. Can't get past this screen. Can someone help me.
its the detecting the remote, cause i can higher and lower the volume
thanks
Paul
thanks
Paul
You need to hold the ok button and i think volume up or somthing, instructions would be on the screen and after a bit it willl pir and go to the next screen.
thanks
Paul
1) Bt scan shows up remote as remoter atv3 and mecool m8s prol> try pairing again everything is ok
2)Only remote is shown and no m8s pro L >Screwed most probably, the box has a dead bt chip like many of us got, send it back
3)Only box is showing up>Problem with remote, try pressing buttons properly or get a new remote
There are currently 1336 users online. 2 members and 1334 guests.
