[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by dally View Post
And perhaps the update error is only happening for those who've already run the tool, which is true in my case, exactly same as adrdidi
It might be related to the reboot recovery image that I used.
Originally posted by adrdidi View Post
Hi, I don’t if it’s your case like mine, but I installed a Mecool M8S Pro L recovery TWRP on my device and I think that’s what’s causing this problem. So since I used TWRP, no matter if I upload a factory image using USB Burning Tool, the OTA update no longer works!
I think I know what the update does. It’s the update to fix the problem from Netflix HD app from opening (error message NW-6-404). It probably has the update so people don’t need to use BurnKeyTool fix.
I don’t need to fix Netflix problem because I already applyed this fix, but I’m just annoyed that I’m not able to use OTA.
Originally posted by kevtheseg View Post
I updated yesterday was installed without issue. Not saying this to be a dick more to let you know that someone else has took this update without issue and also to say I see no difference it's not a full OS upgrade still on android 7.1.2 Kernel is now 3.14.29.Fri 3ed Aug 17.39.51 CST 2018 Build M8S PRO L. userdebug 7.1.2 NHG47L 20180803.173707.V0213
Cannot see any difference
fwiw i have two LB version boxes.one updated without issue.checked netflix hd was working before and after.i did update with a wifi connection.the second box was a different story.using 5g wifi it did not find any update.using 2g wifi it found update but stalled shortly after starting download.so connected to internet with lan cable and it updated no problem.netflix hd worked before the update but not after.i had to install the burn tool key and now it is working again.so it suggests to me this small update is to fix issue with latest youtube app and nothing to do with netflix hd issues.why they cant say what the update is for is beyond me."improve user experience" tells us nothing!
Originally posted by supermal View Postfwiw i have two LB version boxes.one updated without issue.checked netflix hd was working before and after.i did update with a wifi connection.the second box was a different story.using 5g wifi it did not find any update.using 2g wifi it found update but stalled shortly after starting download.so connected to internet with lan cable and it updated no problem.netflix hd worked before the update but not after.i had to install the burn tool key and now it is working again.so it suggests to me this small update is to fix issue with latest youtube app and nothing to do with netflix hd issues.why they cant say what the update is for is beyond me."improve user experience" tells us nothing!
Also, did you check that (latest version) youtube app works ok after this update?
Originally posted by DrNicos View Post
Interesting info: so maybe LAN "helps" to successful update.
I refreshed my Mecool M8S Pro L android tv box with the USB burning tool to the previous build, 20180417.150752.V0213.img. I then tried updating to the newest build, 20180803.173707.V0213 three times:
1 time with the 5g wifi connection
1 time with the 2g wifi connection
1 time with the Ethernet connection
All failed with the same status 7 error message. Can anybody provide me the 20180803.173707.V0213.img file? This is very frustrating. Anybody help please.
Originally posted by LoKin View PostI refreshed my Mecool M8S Pro L android tv box with the USB burning tool to the previous build, 20180417.150752.V0213.img. I then tried updating to the newest build, 20180803.173707.V0213 three times:
I used the same way with the same result! I agree that's very Ugly !
For those which succeed to update their box ,would you please post the "Img" file with update LB version
thanks
There are currently 1779 users online. 1 members and 1778 guests.
