[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by Intrinsic View Post
Originally posted by kevtheseg View Post
Thanks for the response don't think I'll be flashing unt I know it's going to work on the box I have. It's no biggie I've got other boxes to play with Pity about the dev being away but I'll keep an eye out for any further update. With regards to the YouTube app I had to uninstall the updates to get stable playback but it will do 4k without issue as long as I have active cooling running at about 59-65C again thanks
I have even considered doing a factory reset then seeing if I can uninstall it then.
Originally posted by mymo View PostHave you tried uninstalling it via Titanium Backup or Root App deleter?
Inviato dal mio Redmi Note 4 utilizzando Tapatalk
Well... don't flash unless there is a fix for it. I have the same version of this device and opted out of flashing this Rom. Its not just wifi you will have problems with but bluetooth too. And as such won't be able to get past the set up screen wehere you are required to pair the bluetooth on the remote.
It also doesn't help that the chef of this ROM has been MIA for a few months now.
Technically it should be an easy fix, kinda just swapping out files from the current version of this ROm and replacing them with the stock wifi/blutooth files in the stock rom to ensure compatibility with the LB devices. But unfortunately I have no idea how to build or package a ROM.
Originally posted by supermal View Post
Must not be as easy a fix as you think.Megandanz has already tried doing this and not had much success.He has as you say been MIA since.nor has any other custom rom developer come forward with any solutions.perhaps it was a deliberate action for Mecool to prevent custom development of there widevine L1 boxes.i don't really know.so at the moment only the stock rom works with the LB version.with regard to DPI settings it is generally considered that midway between 240 and 320 is best.
As for the DPI settings, I did read a couple of people settling for 280 as their sweetspot, but to me I think it boils down to elligability. Which basically comes down to your physical TV size and distance from it. Long story short, YMMV. Cause right now my DPI is set at 200. Anything smallet and I think stuff is too small and anything bigger and i feel I am wasting space, another benefit of this is that I need to do less scrolling.
Originally posted by Appys View PostHow can I make an external wifi adapter work with this box? Will I have to recompile the kernel and if so does anyone have the kernel source with them for testing?
I asked too but I have not gotten a return so far.
Hello! Please, if you can count on opinions on the subject, thank you in advance. Would it be nice to replace the installed wifi antenna of the M8S PRO L with another, based on the video below? My TV box is distant about 5 meters from the modem of the operator and is unable to receive the signal
https://www.youtube.com/watch?v=LnEMCcIz7jU
5m and it cant get the signal :O ..well join the club..making an external wifi adapter doesnt seem easy but im willing to try if someone gives some directions
Did you watch the video I left as an information base? There, it is advised to replace the wifi antenna of the TV box with another using a pigtail terminal and make an adaptation on the housing (this part seems to be a headache for a mecool m8s pro L). would we really have significant signal improvement? Thankful.
Originally posted by DreamSeason View PostSeems the latest YouTube for ATV update does NOT solve the crash problem... Don't know what the developers are doing with this update.
There are currently 2749 users online. 2 members and 2747 guests.
