[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by natman View Post
Originally posted by mymo View Post
No, Amazon prime doesn't work with any versions of this box. What you can do to watch Amazon contents is to install the Amazon prime Vod addon into Kodi Leia 18: You can find the procedure I posted somewhere in this forum. Through this addon the video quality is up to FHD, but the audio will only be stereo.
the LB version with april update add the microsoft drm and prime video workSorry for my badly english
@Snakx
Please, can you tell us which version of mecool m8s pro L you have? LB with or without voice remote? Which firmware version do you have installed?
Which version of primevideo app have you tested?
Do you have played a full movie or only a trailer? I'm asking this because on my m8s primevideo app plays only the trailer but gives a connection error when I try to play a full movie...
mymo for the resolution i think 1080P
my amazon prime have finished
just in case test with unrooted device or hide this. I use mycanal for TV and have freeze with root. have rename the su file on old.su in system/bon and system/xbin folder and it work.
As soon i have the time. I think tested magisk
sorry for my badly english
Originally posted by Snakx
m8s pro L (LB) with voice remote stock firmware. I can't remember the version of prime video and have just test it (not full movie)
Does Google cast work in this room with any apps other than YouTube? The device gets recognized by any apps supporting chromecast, but I can only beam youtube from the phone to the box
Inviato dal mio Redmi Note 4 utilizzando Tapatalk
Ok, if i install LB rom on my LQ box what (bad) will happend i dont use wifi and blueboot, will bluetooth be bigest problem since you cant skip setup screen, if this is true then can we use twrp rom backup that already have this skipped. And ofc will drm be perserved in this case and is it possible to go back to stock or custom LQ rom after
Originally posted by mymo View PostI see. Well for now Amazon through Kodi is not a bad workaround, for us with a LQ version.
Inviato dal mio Redmi Note 4 utilizzando TapatalkSorry for my badly english
Originally posted by nowso2k18 View Postthe latest Youtube android tv update is freezing terribly - have to uninstall updaes - ?? anybody else had issues ?
There are currently 1420 users online. 1 members and 1419 guests.
