[ROM] Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1)
Originally posted by san_ic View Post
Thanks guys. I did install Netflix and some other apps from Aptoide but there are still issues. Among the apps that I use, Youtube hangs after a bit and Amazon prime does not work.
Pardon my ignorance, i don't know what a leanback launcher is but if what Giannis says holds good then i don't have the leanback launcher in my box. While I may be able to load apps via the usb, it's not something my in-laws will be able to. That's the biggest drawback for me since they live in different city
Originally posted by Thghost View Post
Is there anyone to help me? I want to use NetFlix (android tv) version. Because the remote control is easy to use. Thanks.
Originally posted by san_ic View PostThanks guys. I did install Netflix and some other apps from Aptoide but there are still issues. Among the apps that I use, Youtube hangs after a bit and Amazon prime does not work.
So you'll have to find a solution to each of your problems separately:
1. YouTube hangs: you should update to the latest OTA stock firmware which fixed the youtube issue
2. Amazon prime: no idea, search if others found way to work amazon
3. Don't want to install apps via USB: I think there are a few special apps which look a little bit like Google Play but actually install apks. I think there is one called aptoide?
Originally posted by DrNicos View Post
Generally you can't install firmwares across devices. Unless you think your T95z plus is identical to the mecool m8s pro L. But I doubt that.
Thanks for the answer. The two devices are exactly the same. I also expect comments from experienced friends
It's not enough just to have same specifications as listed e.g. on sellers website. They need to be more identical, like same manufacturer, same motherboard, same wifi chipset, ethernet chipset - these details you don't see on seller websites. I really think they're not the same.
Pardon my ignorance, i don't know what a leanback launcher is but if what Giannis says holds good then i don't have the leanback launcher in my box. While I may be able to load apps via the usb, it's not something my in-laws will be able to. That's the biggest drawback for me since they live in different cityYour mecool box LB version came with M8S_PRO_L-NHG47L-20180316.115110.V0213 stock rom ( atv firmware with mecool leanback launcher , normal remote version). [image of your main screen of the mecool leanback launcher as below].
This stock firmware hasn't ota update yet (the stock rom of BT version box has already two ota updates). So if you have youtube issues the only solution is to uninstall the updates from youtube apk and prevent it to update.automatically again. I haven't Amazon Prime so I didn't test it.Last edited by Giannis; 30 August 2018, 16:51.
Guest
Changelog (20180830):- Ported over latest M8S Pro OEM firmware (20180412.194117.V0213)
- Merged in latest M8S Pro L bootloader and device tree (20180803.173707.V0213)
- Updated to TWRP Recovery 3.2.3-0
- Preserves Miracast from OEM firmware
- Latest build from Open GApps (20180830)
- This firmware is designed for earlier models of the M8S Pro L with the QCA9377 wireless chipset. If you install it on later (non-LQ) hardware, WiFi and Bluetooth won't work.
- TVStock Variant: BURN PACKAGE (980MB IMG file), OTA UPDATE (537MB ZIP file)
There are currently 2212 users online. 0 members and 2212 guests.
